![]() Join Date: Dec 2016
Console Help
So I have this console I bought along with the buckets seat out of a 1971 GMC. My thought was to restore these and put them in my 72 Cheyenne.
Now that i've given the console the once over I'm not sure this is fixable (at least by me) and I think I would prefer the cup holder style instead of these with seat belt holder and ash tray. This one is in decent shape with the exception of the damage in the photo and still has the original Jack Instruction and Storage Tag. Questions: Do we have a member on the forum who restores these? Maybe I could swing a trade for this one. I did a search and found some old post on members who did but those look pretty old. Does this look repairable where the edge has been pushed down and cracked? |
![]() Join Date: Dec 2013
Re: Console Help
Looks like a pretty easy fix with some good epoxy , Spend a few hours cleaning it up and use bronze wool on the chrome surfaces NEVER steel wool that makes rust worse . Bronze wool should be in every tool box it works just as steel wool but won't leave small filaments of raw steel in the surface your cleaning to make it rust even further .
![]() http://www.ebay.com/itm/HOMAX-PRODUC...3D380316364516 http://www.homedepot.com/p/Loctite-0...0788/100371824 |
Re: Console Help
Just as the "G-man" says, that's very fixable. Clean it and prep it, then when you do put the epoxy on underside, glue in and clamp a brace in to strengthen the area. On the outside, take your time to get the break back together tightly. Once you're done, it'll be hard to see the fix
Re: Console Help
Thanks for the advice. I'll give it shot on the repair. Even if I wind up trading or selling it helps its value. And G-man thanks for the tip on the bronze steel wool. Guess I need to toss all my other steel wool out and get some of that to keep my chrome spiffed up.
mgm60 |
![]() Join Date: Jun 2005
Re: Console Help
Best thing for removing rust that I have ever used is Nevr-Dull. Won't damage surface and actually prevents rust.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear Last edited by 70STOVEBOLT; 06-09-2017 at 07:34 AM. |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Console Help
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Console Help
Re: Console Help
My NEVR-DULL is so old it's not even Eagle One, it's still in the old blue can. It lasts a long time!
I've also found that aluminum foil is good for "filling in" scratches on hard-chromed metal. Remove the rust first though.
Re: Console Help
Well... Actually it's tin foil and diet coke , regular coke has sugar and leaves a film .
![]() https://www.youtube.com/watch?v=JkHyARsjNEg |
