Old 06-07-2017, 12:34 AM   #1
66camper
66 custom camper tilt steering column
Hello fellow classic owners. Ive recently picked up a 66 chevy custom camper and have been browsing ideas to give myself more breathing room behind the wheel. I'm 6'2" and 300 lbs. So when I am driving I have the issue on either kicking my door open when trying to use the clutch or when turning I unbuckle my seat belt. So my question is any other manly fellows have this same issue and possibly tried installing a tilt steering wheel to help alleviate the pain? Thanks in advance.
66camper is offline   Reply With Quote
Old 06-07-2017, 01:27 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 66 custom camper tilt steering column
I installed a 71/72 c10 tilt steering in my 65, I'm the same size as you and we are just bigger than the folks back then. I also suggest an automatic for driving pleasure.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-07-2017, 01:30 PM   #3
65chevysub
65chevysub's Avatar
X2. I had a 72 Tilt column put in my 65 Suburban. I don't use the tilt much but my wife does. And if you have the deluxe steering wheel, it will fit on the column, mine did.
65chevysub is offline   Reply With Quote
Old 06-07-2017, 02:19 PM   #4
66camper
Thanks for the replies i will have to start looking for one.
Old 06-07-2017, 03:50 PM   #5
jocko
jocko's Avatar
Let's see some pics of that Custom Camper!! Welcome to the site.
Old 06-08-2017, 01:16 AM   #6
66camper
I'll grab a couple pictures and post soon. Thank you again!
Old 06-08-2017, 11:04 PM   #7
64shortbox
64shortbox's Avatar
I too added a tilt column from a 72 Chevy van. I also didn't like having to raise my right foot up so high to step on the brake pedal so I added a thicker rubber bumper stop - placing the brake pedal a couple of inches closer to the floor. I still have plenty of brake pedal travel. I realize your truck is a stick but you still might try adding a thicker rubber stop to your clutch pedal to bring it down a little. Hopefully you should still have enough clutch adjustment to disengage the clutch completely when you depress the clutch pedal. I'm not sure about these trucks but on my 3 stick shift Pontiacs I had plenty of travel left of my clutch pedal after the clutch disc disengaged but I like my clutch adjusted right off the top with only about 1/4" or so of free play in the pedal.
I slid my van column down as close to the dash as I possibly could and I keep my column in the full tilt up position. I'm not a big guy at 5' 10" 181 LBS but no more gut rub on the steering wheel (I also added a smaller steering wheel) and I don't feel like I'm lifting my leg 3 feet off the floor just to step on the brake pedal.
There is a lot more than just bolting a 72 or so van tilt in our trucks. Since yours is a stick you don't need to worry about the neutral safety switch but you will need to modify it to fit the mounting location. I did mine - 1967 Chevy truck style - drilling a 3/8" hole dead center in the top of my column then using a 3/8" - 24 bolt and a jamb nut as the centering pin. As a plus you can also easily add 4 way emergency flashers since the wiring is already in the column. If you have any questions or concerns please feel free to ask.
Yes, all 4 truck pics are of the same truck - just taken over a span of several years. I just can't seem to leave it alone for very long.
I also included a shameful pic of my 62 Catalina, Tri-Power, 4 SPD, 3:42 Posi, 8 lugs and Lots of clutch pedal travel. Unfortunately it hasn't seen the light of day in over 10 years. I dropped the front suspension out from under it to rebuild it & never got around to putting it back together.
64shortbox is offline   Reply With Quote
