06-07-2017, 02:38 AM | #1 |
1959 wiper system - need help
Hi all
My -59 has the stock electric motor. It runs, but parts are broken and I have given up on it. The truck is a daily driver in a rainy area. It gets annoying when the motor reverses into park position. And I would love to have intermittent wiping action. All this means I ma looking at an electric - electric conversion, basically I want a more modern setup It seems all the "kits" out there are for vacuum - electric conversion. Which means I think, that they will not bolt into my truck. Should I just go full custom? I have no idea where to look or what to look for, please help |
06-07-2017, 12:40 PM | #2 | |
Hollister Road Co.
Re: 1959 wiper system - need help
06-07-2017, 04:53 PM | #3 |
if the park function is the only problem and your going to throw out the motor any way, you can repair it
the switch is like a set of points where the cam is always rotating on the point arm the cam eventually wears thru the arm causing the switch to work intermittently i have fixed the arm before by silver soldering a piece of copper to reinforce the arm you'll need to drill out the rivets that hold the motor together and then screw or glue the housing back together easy peasy
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
06-07-2017, 10:16 PM | #4 |
I have Newport Wipers in my 57 and like it pretty well. It was a bolt-in. It has intermittent and two speeds, and pushing the button starts the washer and swipes the wipers three times. I have a reservoir with pump out of an S10 but haven't mounted it yet.
