06-07-2017, 08:30 AM | #1 |
What did I do wrong???? Ahhhhh!!!!
On my 64 I did a pwr steering conversion using capt. fab's bracket kit. I didn't pay attention to the center link to frame clearance before
removing the old manual box. I have about 1/4 in clearance...after cleaning all the dirt of the frame and center link. It's gotta be too close. I can't believe I set the template too low to mark the holes for mounting the box......at least I don't think I did as i'm very very careful with stuff like this (at the dealership I work at, I do a lot of installs that require templates like spoilers etc.) My questions are: 1. Is the box sitting too low? 2. Can I just grind the back side of the center link slightly flat to increase clearance without making it unsafe? 3. Is the new pitman are up far enough? |
06-07-2017, 10:49 AM | #2 |
Never Ending Projects
Re: What did I do wrong???? Ahhhhh!!!!
Your pitman arm looks fine. The splines have a taper to them, so it will only go up so far. As for clearance, it's not rubbing that's good. When you turn, the center link will move away from the crossmember as it moves on the arc of the pitman and idler arm. The center link looks parallel to the crossmember, which is what you need. As long as nothing is rubbing when you go full left to right, you're good.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
06-07-2017, 11:30 AM | #3 |
X 2. That's about the same clearance mine has.
06-08-2017, 09:58 AM | #4 |
What a relief, thanks guys....
06-08-2017, 12:52 PM | #5 |
But Found Her 25yrs Later!
Here's how the template was made :
http://67-72chevytrucks.com/vboard/s...d.php?t=438509
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
06-08-2017, 02:30 PM | #6 | |
06-08-2017, 03:21 PM | #7 |
I'm assuming that pics takin with the truck sitting on the ground and not on jack stands mine was real close to but did not a rub mark after 2 yrs!!!
06-08-2017, 05:16 PM | #8 | |
looking at it, the center link is bent. Mine originally had this issue because someone tried to pull the truck from the center link. If you look at my used replacement, it's straight. I was looking at mine last night and it has about the same clearance that you show.
