Old 06-07-2017, 01:51 PM   #1
blown240
blown240's Avatar
Strange Shoe and Drum Wear
In May of 2015 I replaced all my breaks. From the shoes to the booster, even hard lines, everything was new except the drums, that I had turned.
I noticed in the last week or so that my brake pedal was moving farther before I stopped, so this morning I went and adjusted all the shoes.
Its a 61, so no auto adjust, and drums front and rear.
On 3 wheels, the shoes and everything just needed minor adjustments. But the drivers front was a different story.
The rear shoe is almost all the way gone, and the drum has 2 HUGE grooves in it. The grooves are probably from Rivets in the shoes.
Obviously I need to change the drum and shoes on this wheel, but what could cause this to happen to only 1 wheel? If it matters, the truck has always slightly pulled to that side when braking.... SLIGHTLY.
Here are some pics:
Front shoe, looks Ok, even though had abnormal wear:
Rear Shoe is mostly worn out:
Drum has grooves:
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 06-07-2017, 04:06 PM   #2
MikeN
MikeN's Avatar
Re: Strange Shoe and Drum Wear
Rear shoe was the only one moving outward when brake pressure was applied. Has to be some sort of installation error - was the front shoe hung up on the backing plate somehow?
MikeN is offline   Reply With Quote
Old 06-07-2017, 04:25 PM   #3
blown240
blown240's Avatar
Thanks for that reply. That makes sense. Im going to get a new drum and new shoes in the next several days. I will double check that they aren't bound up somehow.
Old 06-07-2017, 07:32 PM   #4
MikeN
MikeN's Avatar
An old timer once showed me how to put a dab of white lithium grease everywhere the shoes contact the backing plates. I have also seen backing plates on very high mileage vehicles where the shoes over time have worn right through the backing plate in places where they make contact. Hopefully you'll find that it's something easy like that to fix.
Old 06-07-2017, 07:43 PM   #5
blown240
blown240's Avatar
Thanks MikeN!
A buddy saw my pics and is giving me the drums he took off his 66 for a disc swap. So that will save me a bit of money!
Old 06-08-2017, 12:21 AM   #6
AcampoDave
AcampoDave's Avatar
Could ot have something to do with the emergency brake?
AcampoDave is offline   Reply With Quote
Old 06-08-2017, 12:32 AM   #7
'63GENIII
'63GENIII's Avatar
Ive had weird things like that happen when 1 side of a wheel cylinder starts hanging up. All of the pressure is diverted to the opposite shoe. Id pull the dust boot off and look for brake dust / mud in large amounts.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 06-08-2017, 08:32 AM   #8
Enduro55
Wheel cyl or flex line
Enduro55 is offline   Reply With Quote
Old 06-08-2017, 11:43 AM   #9
blown240
blown240's Avatar
Good tip on the wheel cylinder. Its new, but ill check it for sure!
Old 06-08-2017, 11:54 AM   #10
1966shortwide
On the picture of the rear shoe it look's like backing plate is bent , has some bend's right in line of jack stand. This will cause misalignment of shoe and the right front brake will have better contact area and pull to right braking.
1966shortwide is offline   Reply With Quote
Old 06-08-2017, 12:00 PM   #11
blown240
blown240's Avatar
good eyes 1966shortwide. Ill have to look at that. Even though its been pulling to the left, its still worth checking!
thanks!
Old 06-08-2017, 12:10 PM   #12
1966shortwide
oh , guess i did not read correct LOL . Still could be the cause of the pull.
Old 06-13-2017, 10:17 PM   #13
stsalvage
Scrapper 1
stsalvage's Avatar
When you take your brake shoes off look at your backing plates If they have groves where your brake shoes move back and forth.You need to wire feed and grind them down smooth Then put white lithem grease on all 3 pad that the brake shoes rest on.Make she you pivic bolt on top where you put all your springs is not bent.Remember to de arch your shoes so that they apply to the center of the brake drum then when you put more pressure the brake shoe flatten's out against the brake drum
stsalvage is offline   Reply With Quote
Old 06-14-2017, 11:48 AM   #14
blown240
blown240's Avatar
Ill check that. Thanks!
