Old 06-07-2017, 03:56 PM   #1
AnobleL74
lowered truck rides rough rough, need help
Hi All
My truck has all new stock suspension, shocks etc, except springs.
it has been lowered, not exactly how, but guess shorter springs since all the other suspension parts are stock.
need advice on how to get a softer smoother ride,
i looked at our FAQ site but did not find anything
here are some photos so you can see the ride height.
http://s958.photobucket.com/user/al1...?sort=3&page=1
thanks
Allan
AnobleL74 is offline   Reply With Quote
Old 06-07-2017, 04:13 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: lowered truck rides rough rough, need help
Usually, shorter springs are stiffer, but I would check your shock absorbers to see if they have enough travel (make sure they do not bottom out before the suspension reaches full travel). Ride comfort/quality is subjective, especially with our trucks.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-07-2017, 04:27 PM   #3
forestb
forestb's Avatar
If it is lowered a lot in the rear it might need shock relocators or it might be riding on the bump stops. The link in your post did not work for me.
forestb is offline   Reply With Quote
Old 06-07-2017, 05:02 PM   #4
AnobleL74
sorry link won't open for you, i tried to upload some pics to this post but they will not load up.
the photo bucket link should open, not sure whats wrong,
some measurements;
center of hub to wheel well lip
front 16 1/2 inches
rear 11 inches
all 4 bump stops have about 1 inch clearance.
thanks
Allan
Old 06-07-2017, 05:18 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Also what is the height of the tires. I had some low profiles that made things real rough!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-07-2017, 05:50 PM   #6
AnobleL74
rear tires 29 inches tall 255/60R18
front tires 28 inches tall 255/55R18
Old 06-07-2017, 11:52 PM   #7
rvrfoot
If the bump stops only has 1 inch. Maybe its hitting going down the road.
rvrfoot is offline   Reply With Quote
