![]() ![]() Join Date: Feb 2009
What the heck, I actually still want nutted sport mirror backing plates. Anyone?
Long story short, I've struck out many times on these. Just a comedy of errors, so to speak.
Anyway, reasonable to no pitting please. I only need the LH side, but a pair works as well and I'll pay good $ for them...... If you need a motivation, I'm motivated to pay up to $50 shipped for a nice pair. I may have some trade bait, such as a standard NOS lighted marker lens? Come to think of it, if you need the stainless grade 8 1/4-20 screws for these, I do have NOS available. FOUND, thank you Randy
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-14-2017 at 09:26 PM. |
![]() Join Date: Jun 2009
Re: What the heck, I actually still want nutted sport mirror backing plates. Anyone?
I am confused, what exactly are you looking for and what style ? Because I sold you those, they do not work ?
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#3 | |
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Jun 2014
Hey Tony! Randy here. I think we've helped each other out before. I have one. Don't know if it's left or right. You'll have to run a tap through the welded on nuts to clean them up. Price - 0.00 if you want it. If you want a pic PM me a # to send it too.
LMK, Randy |
Tony - it's a L/H (driver's side). Pretty good shape. One screw has broken off into the nut but has been drilled out for an easy-out.
B/R, Randy |
I've got a set of original backer plates $37.00 shipped for pair....Jack
71 C-20 07 Magnum RT AWD |
Thanks for the great gesture Randy, but I think I'll pass. Have never used a tap nor have the tools. Only thing I've ever done is, long ago, I used one of those "reverse" drill bits to remove two valve cover screws I over-torqued........Ha! Nut driver since........................Speak of a tap, interestingly enough, the door jam switches were stripped on the rebuild. I figured, and by reading it was the sheet metal. Picked up some NOS. Happy to say it turned out to be the switches. On second thought, if you have no use for it, sure what the heck. Can you use some screws for these?
54blackhornet I sent a PM. Thank you.
Hey Tony! I was messing around in the shop this AM and went ahead and drilled out the broken screw and tapped out the nut plates. Came out good. I appreciate the offer of screws but I'm using the plates that take the self tapping screws. Anyway, PM me your mailing address and I'll send it out to you. Before you use it make sure all the screws line up correctly (mount it to the mirror).
B/R, Randy |
#9 | |
| Bookmarks |
