Old 06-09-2017, 01:04 AM   #1
mosel70
What's Normal Temp for '70 C10 396?
My stock radiator and belt-driven fans couldn't keep my 396 (402) from overheating while stopped and in gear. I put in Mishimoto's three-core alum radiator and dual electric fans (2600 cfm) specifically made for 67-72 Checy C10s. Last summer I put in Summit's high volume water pump and a Mishimoto 180 degree thermostat. With 87 degrees outside and stopped and in gear, I'm running 196-202 degrees with IR temp gun pointed at coolant hose just off thermostat housing, but temp gauge needle is just in the red (new temp gauge). I'm running the fans constantly while the engine runs.
As temps are getting higher here in Las Vegas, what is the highest temp I should allow before getting alarmed? Any way to get the temp down?
mosel70 is offline   Reply With Quote
Old 06-09-2017, 06:31 AM   #2
Ken B
Re: What's Normal Temp for '70 C10 396?
I would try another gauge inside the truck, it doesn't seem accurate. The 427 in my Chevelle runs between 190-200 on the hottest of days and it has all stock cooling components.
Ken B is offline   Reply With Quote
Old 06-09-2017, 07:58 AM   #3
Alex V.
Alex V.'s Avatar
Sustained temp probably shouldn't be over 200, but I wouldn't expect damage from momentary spikes of less than 215-220.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 06-09-2017, 08:03 AM   #4
weq92f
weq92f's Avatar
My '70 402 runs right around 195 when idling with A/C running and in gear, like at a stop light. Running straight fan against a radiator without shroud.
The temp will go to about 220 and sit there if the truck continues to sit and build heat. Once we start rolling, the temp comes back down.
If it's extreme enough, I'll slip it into neutral and bring the RPMs up to around 2000, which will also bring the temp stable or back down.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-09-2017, 09:01 AM   #5
clay68c10
clay68c10's Avatar
My old 68 would run at 205 with a .030 over 454 in Dallas summertime, a/c on, in traffic or idling or whatever. I think I was running a 195 thermostat. I datalogged my EFI just to watch the temp, it was pretty steady. I was running a Lincoln MK8 fan with a PWM controller. The fan was almost always running at 50% or more once the truck got warmed up.
I recalibrated my stock gauge, it would always be on the edge or in the red. A different resistor on the back got the needle where I liked it. I don't remember what resistance did the trick, that's been a while ago.
Big blocks do run hotter than small blocks, for sure.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-09-2017, 09:11 AM   #6
engineer_gregh
engineer_gregh's Avatar
I don't trust the stock temperature gauges. I have a built 402 and had the same issues you are seeing. First thing I would suggest is to add an aftermarket under dash gauge to get a more accurate reading. If in fact you're running hot you might want to play with your timing to see if it will help. Big blocks do run hotter, but I am uncomfortable with any reading above 200 degrees. I'm running dual 1600 cfm fans but with the stock 4 row radiator.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 06-09-2017, 11:49 AM   #7
davepl
davepl's Avatar
I wouldn't trust the gauge. But if that were my gauge in my truck, that's about 220F, which is getting toasty.
My truck will not hold it's temp in warm (85+) Seattle weather with the AC on, so I imagine you'd struggle a bit in Vegas. Without the AC on it should be able to manage though.
Get a standard thermal temp gun and point it at the thermostat housing, that's how I check my actual temp. I have one in the glovebox right now because I'm chasing a similar issue on my own 1970 C20 396.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
