Old 06-10-2017, 01:36 AM   #1
CISCOS65
Need some help fellas
So I have a little dilemma hoping to get some help here. I have some wheels that are 15x8.5 and having a hard time deciding what size tires to put on them while deciding what looks best. I have a 65 long bed on air hoping someone has pictures and sizes to get me in the right direction! thanks!
CISCOS65 is offline   Reply With Quote
Old 06-10-2017, 12:29 PM   #2
forestb
forestb's Avatar
Re: Need some help fellas
fleetside or step side?
forestb is offline   Reply With Quote
Old 06-10-2017, 12:41 PM   #3
CISCOS65
Fleetside
Old 06-10-2017, 01:47 PM   #4
rvrfoot
235 75 15Name:  DSCN0752.jpg
rvrfoot is offline   Reply With Quote
Old 06-10-2017, 01:54 PM   #5
CISCOS65
Originally Posted by rvrfoot View Post
Your wheels are 15x8.5?
Old 06-10-2017, 01:56 PM   #6
rvrfoot
I think thay are i will look when i go too my shop.
Old 06-10-2017, 01:57 PM   #7
CISCOS65
Cool thanks I was gonna use that size but was told they will have a slight stretch
Old 06-10-2017, 11:42 PM   #8
Captainfab
60-66 Nut
An 8" wide wheel is about the max width for a 235/75R15 tire. I believe the tire manufacturers recommend a max width of a 7" wide wheel. On my '66 Suburban I am running 275/60R15's on 15 x 8 Rally wheels. Since your truck is lowered, you will likely have to go a little narrower like a 245 or 255. Of course this is also assuming your differential is the original width.
http://www.67-72chevytrucks.com/vboa...2&d=1243225524
Old 06-13-2017, 02:33 AM   #9
CISCOS65
Bump for help
Old 06-13-2017, 06:35 AM   #10
PGSigns
PGSigns's Avatar
I have 15X8 on my 66 and 235 70 fronts and the wheel is wider than I like. Trouble is any wider and the tire hits the fender. On the rear with 4" of back spacing and 275 60's the tires rub the inside of the wheel tubs when going in steep driveways. On my 65 that was on air 15X7 and 225's was all I could get to work on my setup and have room to turn when running low. Also you dont list the back spacing. A 15X8 with 4" of back spacing will hit the lower control arms with drop spindles and require a good bit of grinding on the lower control arms so you will have to test your wheels. If it were my truck I would be looking for another set of wheels. Not sure what else we can tell you.
Jimmy
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-13-2017, 12:03 PM   #11
Chevy Fleetside
Chevy Fleetside's Avatar
255/60 up front and 275/60 on the rear. 8" rims.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
