![]() Join Date: Nov 2013
Bed wood cutting
Making own bedwood......Can use router or table saw for groove, but what is best way to make outer edge lower than middle of plank?
Re: Bed wood cutting
ho70. I have done a couple of wood beds starting with rough lumber. I only used my table saw and a dado blade to cut the grooves. I guess I should add that I used a planer to plane the rough lumber. If I remember right I set the dado blade to cut the deeper grove first and reset the blade to cut the other. You can do this with your saw blade if you don't have a dado, it just takes longer.
Last wood bed I helped with, we used a table saw and a router table. Turned out nice.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
![]() Join Date: May 2002
A couple setups with a router edge guide and you can knock out the groove and outer edge in a hurry.
'72 C10 Short Fleet "Praise the Lowered" |
thanks guys, will give it a try
![]() Join Date: Mar 2003
The Older Generation
I also used my large thickness planer, table saw, router table, and miter saw to trim the ends. LockDoc
![]() Join Date: Jun 2009
I actually mad the ones on my truck shallower than factory so the wear bar actually sticks up a bit further, the only issue with doing them deeper is your wear bar only serves as a hold down now and does not truly protect the wood.
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
