Old 06-11-2017, 08:35 PM   #1
BLT-NT-BOT
Automatic trans shift linkage
This linkage is off a 71 Chevy 1/2 ton auto column shift. 40.00 shipped in the US
BLT-NT-BOT is offline   Reply With Quote
Old 07-14-2017, 08:12 PM   #2
BLT-NT-BOT
Re: Automatic trans shift linkage
Ttt
Old 07-14-2017, 08:27 PM   #3
randy500
That's 4x4 linkage isn't it?
randy500 is offline   Reply With Quote
Old 07-14-2017, 08:57 PM   #4
BLT-NT-BOT
I pulled it off a 2 wheel drive truck. The ones on the three 4 x 4'sI have look like the picture below.
Old 07-31-2017, 11:19 AM   #5
BLT-NT-BOT
Still available
Old 07-31-2017, 12:42 PM   #6
19702wdc10
Active Member
Hello,
I have a 1970 2wd with 250 and turbo 350, will this work with a straight 6?
Joe
19702wdc10 is offline   Reply With Quote
Old 07-31-2017, 01:47 PM   #7
BLT-NT-BOT
Originally Posted by 19702wdc10 View Post
Hello,
Joe
I am going to assume that it would because none of the linkage has anything to do with the motor. this came out of a truck that had a turbo 350 and a small block V8.
Jothan
Old 08-02-2017, 11:27 AM   #8
19702wdc10
Active Member
The reason I ask is that I was told that the transmission on a straight 6 drivetrain sits a littler further back than a V8.
Do you have the bolt that attaches on the top of the rod?
Old 08-02-2017, 12:06 PM   #9
BLT-NT-BOT
I will look when I get home from work today, but I'm thinking that I don't have it or it would still be on the rod.
Jothan
Old 08-02-2017, 06:43 PM   #10
BLT-NT-BOT
Doesn't look like I have the bolt.
Old 08-06-2017, 09:39 PM   #11
19702wdc10
Active Member
I will take it.
Received PM and money sent
Joe
Old 08-07-2017, 07:02 PM   #12
Classic Bowties
Always on the hunt...
Jothan
Jothan, the pictured linkage shift rod looks to have been bent/modified to maybe fit a custom application or motor/trans position setup. The different auto linkage setups were C/K series and motor specific, have a look at the below thread link for some labeled side by side comparison pics. Mel
Auto linkage pic thread: http://67-72chevytrucks.com/vboard/s...d.php?t=738509
Classic Bowties is offline   Reply With Quote
Old 08-12-2017, 12:49 PM   #13
ryanv70c10
Although I have limited C10 experience, I can tell you that in passenger cars, the trans location is the same from inline 6 to small block.
ryanv70c10 is offline   Reply With Quote
