06-11-2017, 10:08 PM | #1 |
Door Jamb Switch?
So what's the install trick preventing the wire to not twist and break?
06-12-2017, 12:51 AM | #2 |
Post Whore
Re: Door Jamb Switch?
before I put mine in I spun the switch ccw about 6 rounds then when you screw it in the wire unwinds back to normal untwisted..
06-12-2017, 07:33 AM | #3 |
Ha, got it. Curious did you have a single white wire only?
06-12-2017, 01:12 PM | #4 |
I removed the trim panel and cut a hole with a hole saw behind it. Then installed the new switch and then attached the wire.
My wire had fallen down into the panel before I started so I cut the hole to fish it out. Made the job much easier and the hole is completely covered/ invisible with the trim panel in place. |
06-12-2017, 01:48 PM | #5 |
Post Whore
The switch is nothing but a ground..only one wire to it...opening the door completes the circuit to ground..hot goes directly to the light..
No trim panels on my truck.. |
06-13-2017, 10:32 AM | #6 |
I had the same repair to do with both switches. Mine had rusted on the back of the switches and the wire had fallen, I was able to fish them out without cutting holes. I also just did the twist thing with the wire, and then they untwisted with the installation of the switch.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
