Old 06-12-2017, 09:35 AM   #1
Jason Banks
Jason Banks's Avatar
WTB - Inline 250 Intake Manifold PCV Valve Fitting
Out of my 3 intake manifolds...only 1 had this fitting and I broke it trying to get it out.
Jason Banks is online now   Reply With Quote
Old 06-12-2017, 09:57 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: WTB - Inline 250 Intake Manifold PCV Valve Fitting
I have 4 , I'll try some pb blaster and a little heat to see if I can get one out intact .
Grumpy old man is offline   Reply With Quote
Old 06-12-2017, 11:38 AM   #3
Grumpy old man
Ok , I have one for you ... That is NOT a screwed in fitting it is a pressed in fitting It takes heat and penetrant to pull it out working it slowly from side to side . I'll post pictures as soon as it cools down ...
anyone with a hard to find vacuum leak should look at this fitting the one I pulled had been slathered with red rtv sealant .
Old 06-12-2017, 12:01 PM   #4
Grumpy old man
1st pic shows NO threads it's a pressed in fitting
I bead blasted it to clean it up , You can see NO threads
$10.00 to Paypal kdwholesaletools@gmail.com
Old 06-12-2017, 12:14 PM   #5
Jason Banks
Sent you paypal.
That one looks a little different than what I had. Mine just came straight out the top with no 'angled block'.
I could have told you the non threaded part...since I have 2 manifolds that don't have anything at all in them.
I'll definitely put some sealant on it when I reinstall.
