Old 06-12-2017, 01:30 PM   #1
tabber
tabber's Avatar
1970 Jimmy Heating and AC opinion needed
Vehicle is a 1970 Jimmy with factory A/C. Has round ball vents in dash facing passengers. The vehicle is missing all components to A/C system except the heater boxes under dash and engine compartment. I don't plan on replacing the missing A/C components.
The dash has been brutally hacked up to install a CB and din style radio, which I am planning on returning to stock configuration.
I am in possession of a non-A/C dash front and components.
Questions are:
Should I replace entire dash front so it is non-A/C correct or just the radio section?
Would it be in my favor to leave the A/C ball vent section of the dash in place and somehow route vent tubes to these outlets for passenger comfort?
All opinions or ideas are wanted, thanks in advance.
JT.
tabber is offline   Reply With Quote
Old 06-12-2017, 02:54 PM   #2
6768chevylover
6768chevylover's Avatar
Re: 1970 Jimmy Heating and AC opinion needed
Do you still have a solid cap on it or a soft top?
6768chevylover is offline   Reply With Quote
Old 06-12-2017, 04:14 PM   #3
tabber
tabber's Avatar
I'm going to go with a soft top.
Old 06-12-2017, 04:30 PM   #4
hemi43
hemi43's Avatar
Then it's just as well you don't plan on getting the AC to work because it's useless with the soft top. IMO, I would replace the dash if it's as hacked up as you say. This way you'll be able to fix the CB damage as well as get rid of the A/C vent holes.I would also get rid of the A/C underdash and engine compartment box to clean things up and replace it with a non-AC heater box. You will have to clean up the firewall holes if you do this because A/C used different holes.
hemi43 is offline   Reply With Quote
Old 06-12-2017, 05:16 PM   #5
tabber
tabber's Avatar
I was wondering if those a/c vent outlets on the dash would be nice for the heater/vent air. If not will go with full dash face replacement.
Old 06-13-2017, 03:31 PM   #6
6768chevylover
In a truck the heater lower vent and def. vents are more than enough for warmth but I too am in the process of switching to a non/ac box in my blazer and deciding what to do with the ac vents. the PO did a hack job on the engine comp ac box and gutted the internal box. lucky for me I have spare non ac boxes. just trying to figure out the a/c vents since there is only 2 holes to work with in the non a/c box...
Old 06-13-2017, 03:37 PM   #7
tabber
tabber's Avatar
I'm sure there is a "Y" splitter available somewhere. In my case, I was thinking it would be nice to have vents that I can direct the air towards the driver/passenger using the A/C dash vents. Maybe I'm thinking too much.
Old 06-15-2017, 05:23 PM   #8
mister.freeze
mister.freeze's Avatar
what does a non-a/c heater box look like compared to an a/c one?
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
