Old 06-14-2017, 07:00 AM   #1
Swedchevy67
Steering
Not sure if this is the way, feel free to coment.
Swedchevy67 is offline   Reply With Quote
Old 06-14-2017, 07:58 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Steering
Did you dimple the steering shaft for the lock screw to set in?
Thread locker on the lock screws?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-14-2017, 08:08 AM   #3
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Steering
You need a collapsible link in there. If in the event of a front end collision bad things can happen to your face and chest area.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 06-14-2017, 10:44 AM   #4
Swedchevy67
Re: Steering
No, but I will do now! Thanks
Old 06-14-2017, 10:49 AM   #5
Swedchevy67
Re: Steering
I thought the steel U-joint was the collapsible part?
I bought this tilt steering column with this parts, and he told me nothing about a second link.
Are you sure?
Old 06-14-2017, 11:01 AM   #6
demian5
demian5's Avatar
Re: Steering
The first picture in his post is the part that collapses. That's why they have shear pins in them, not bolts.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 06-14-2017, 11:04 AM   #7
kwmech
Re: Steering
U-joint needs to go further onto the steering box to the next set of splines with the set screw in between
Old 06-14-2017, 11:08 AM   #8
demian5
demian5's Avatar
Re: Steering
Awesome catch there!
1986 C20 Scottsdale
Instagram: C10sofOC
Old 06-14-2017, 11:26 AM   #9
kwmech
Re: Steering
I do quite a bit of custom steering and suspension work on all types of vehicles, trained eye.. And big pics on my monitor
Old 06-14-2017, 11:27 AM   #10
Swedchevy67
Re: Steering
So if I understand you right, this steering is safe?
Old 06-14-2017, 11:32 AM   #11
kwmech
Re: Steering
Yes, as long as it is installed correctly and is on all the way. How much engagement do you have with the Double D shaft and the slide?
Old 06-14-2017, 11:35 AM   #12
Swedchevy67
Re: Steering
Yes I have some doubt about my installation. I will do so.
On my box there is a pin (you can't see it on the picture) on the top of the axel (spline) that I need to cut. Otherwise I can't get the U-joint in place as you prefer.
To cut that pin isn't a big deal I suppose. It will not change the steering box function, would it?
Old 06-14-2017, 11:37 AM   #13
Swedchevy67
Re: Steering
About 20 centimetres (200 millimetres)
Old 06-14-2017, 01:47 PM   #14
kwmech
Re: Steering
More than enough, even after shoving the splines on the rest of the way
