06-14-2017, 06:24 PM | #1 |
Blue 67
Bellhousing differences
Is there a difference between 67 C20 bell housing with C10 or 68 and later models? If yes, can they be swapped? I am thinking about a transmission upgrade and I don't see much about 67 and/or C20s.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
06-14-2017, 06:41 PM | #2 |
Re: Bellhousing differences
Yes, they're the same. The frame is the same, as is the engine, body transmission, interior... etc. The differences are things like suspension ball joints, and bushings.
06-14-2017, 06:48 PM | #3 |
1967 model year was the last year for the SM420 4-speed Muncie transmission. The 420 [and 3-speed Saginaw, iinm] used the GM Bellhousing, p/n 3815891, with a 4-9/16'' opening.
1968 model year and later, used the SM465 4-speed Muncie, and had the GM p/n 3925505 bellhousing, with a 5-1/8'' opening. So, no. You could have a machinist open up the smaller opening to 5-1/8'', but it might be easier and cheaper to find a '68 and later bellhousing, if you wanted a 465 tranny. The 465 is longer than the 420, so either the tranny mounts would need to be moved or a 465 crossmember swapped over to use the later transmission. But now I see you have a ''3-on-the-tree'' 3-speed Saginaw. So it may use the smaller diameter bellhousing even later than 1967... I know something about 4-speeds, but the Saginaws are a mystery to me. Sorry to add to the general confusion. Either bellhousing will mount to an L6 or V8 Chevy engine. There are not different bellhousings per weight class, 10, 20, 30. One exterior size fits all.
06-14-2017, 08:21 PM | #4 |
Blue 67
Thank you very much.
06-14-2017, 10:53 PM | #5 |
What tranny you swapping in? I am going to a T5 sometime soon.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
06-15-2017, 12:00 AM | #6 |
Blue 67
That is were I am heading too. I am doing a lot reading to see what parts I need.
06-15-2017, 02:13 AM | #7 |
I don't think the T5 uses the older cast iron bellhousings.
06-15-2017, 08:13 AM | #8 |
The Older Generation
If you haven't already, check this thread out..... http://67-72chevytrucks.com/vboard/s...d.php?t=438224 LockDoc
06-15-2017, 03:48 PM | #9 | |
Blue 67
06-15-2017, 10:21 PM | #10 |
06-16-2017, 07:48 AM | #11 | |
Length of the trans won't affect mounts, but possibly require driveshaft mods.
06-16-2017, 05:09 PM | #12 | |
Personally, I'm happy with the dependable SM465. A buddy had a T5 in his S/10 and we were always pulling that thing out for repair. [Although one time it was his differential that was making noise and the tranny was OK.] So I don't trust manual trannies that use ATF instead of good 'ole 90 weight. I could be tempted by an A833, if one ever comes my way. But I'm used to the Muncie 4-speed. Hyd clutches are another device that I recall an acquaintance constantly moaning over, too. I've had the '68 Stepside since 1973 and the '71 4x4 Jimmy since 1995, so I'm an old dog, and set in my ways. [In response to your comment: the 4WD SM465/NP205, does mount to a crossmember on the [K/5] K/1500, but I'd have to crawl under the C/10 to verify if that's true of 2WDs, so I'll just take your word for it.]
03-18-2020, 09:53 PM | #13 |
Bringing this back from the dead for some advice:
I've got a starter pad broken on th bellhousing in my 67 and have a 68 (on the title) parts truck available. Broken bellhousing is P/N GM9 3815891 The spare is GM5 3925505 Both trucks had a 3 speed, though the broken one was on the floor and the spare was on the tree. Can anyone confirm them as interchangeable or do I need a new bellhousing entirely? (pics should be uploading) Thanks in advance, fellas. |
03-18-2020, 10:19 PM | #14 |
They don’t interchange.
Different size opening where the trans input bearing housing fits. Post #3 has the info for that. |
03-18-2020, 10:23 PM | #15 | |
I was hoping the fact that I had two 3 speeds that it'd work. Never easy, is it? Last edited by LockDoc; 03-18-2020 at 11:37 PM. Reason: You have to be a premium member to post a Want To Buy |
03-18-2020, 11:38 PM | #16 |
There is a way to use a 505 bellhousing with your trans.
Use a spacer ring like this. https://www.advanceadapters.com/prod...-down-to-4686/ |
