Old 06-14-2017, 09:51 PM   #1
custom10nut
custom10nut's Avatar
Factory Tach needle reading when truck is off?
What SHOULD the factory tach needle read when the truck is off? The reason for asking is I think I've found why it reads low since I "cleaned up the face" a few months ago.
It appears bent.
That being said, is it possible to carefully "bend it back"?
custom10nut is offline   Reply With Quote
Old 06-14-2017, 10:14 PM   #2
harpo231
harpo231's Avatar
Re: Factory Tach needle reading when truck is off?
It should read "0" Be careful they are fragile
harpo231 is offline   Reply With Quote
Old 06-14-2017, 11:33 PM   #3
custom10nut
Then yup, it's bent. It rests below zero.
I first got the hunch when I noticed it was reading consistently low up to about 2k.
What material is the needle?
I'm hoping its metal.
Old 06-16-2017, 11:26 PM   #4
custom10nut
Is it possible to remove the needle, or at least the center button?
Old 06-16-2017, 11:40 PM   #5
Coley
Coley's Avatar
...only if you are a jeweller.
to my recollection the center button is part of the main face stamped out with a top orange round thing.....so not removeable.
The tach swings back and forth in behind this raised surface....not attached it I don't think.
This is a procedure for early morning, after a coffee...on a work bench with the tach head fully removed, well lit area....small jeweller like tools available....and 412 tons of patience and very careful steady hand work.
...just my opinion.
...or ask T-Bone how to do it. He'll know.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 06-17-2017, 12:56 AM   #6
custom10nut
Thanks, I sent him a pm:metal
