Old 06-15-2017, 06:48 AM   #1
flykelley
Truck starting in drive
Hi Guys
I have a 69 2 wheel drive that I did a 5.3 swap with a 4l60E trans swap. Been working on getting the little items all to work right. Got the back up lights working, had to install a new neutral safety switch. The truck starts in Park, neutral and Drive! Have tried to make adjustments but so far no luck on that fixing the starting in drive issues. Any suggestions?
Thanks Mike
flykelley is offline   Reply With Quote
Old 06-15-2017, 09:25 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Truck starting in drive
Are you using the factory NSS on the column or the one on the side of the 4l60e?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-15-2017, 02:50 PM   #3
flykelley
Using the one on the column.
Mike
Old 06-15-2017, 02:57 PM   #4
davepl
davepl's Avatar
Disconnect the purple wire from the NSS, hook up a continuity tester (or meter), and verify that as you sweep it through its motion it goes off and on and various places.
If not, and I suspect not, then the NSS is bad.
Make sure you don't have any BRANCHES in the purple wire. It's a series circuit, there are no parallel runs in it.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-15-2017, 03:26 PM   #5
flykelley
Thanks I'll give that try. It is a new NSS from Advanced auto parts.
Mike
