Old 06-15-2017, 07:16 AM   #1
chazdo2
1971 chevy pu alternator problem
I just rewired my entire truck. Apparently I threw out my voltage regulator it was old rusted and I didn't even know what is was. Now everything on the truck works fine new engine and all except the charging system doesn't work. All lights starts signals everything works. Can anyone tell me what to do? Can I buy an alternator or generator that doesn't need a voltage regulator? Can somebody tell me how to wire my existing alternator the right way?
chazdo2 is offline   Reply With Quote
Old 06-15-2017, 07:45 AM   #2
leftybass209
leftybass209's Avatar
Re: 1971 chevy pu alyternator problem
One thing at a time. There are two types of alternators... externally regulated, and internally regulated. I won't make any assumptions to the kind of alternator that's on the truck now. Look for some numbers on it, or take a picture of the back of it and we can go from there.
What kit did you wire the truck with? Did you wire it for an external regulator or not? What wires do you currently have at the alternator?
leftybass209 is offline   Reply With Quote
Old 06-15-2017, 08:29 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This should help.
http://67-72chevytrucks.com/vboard/s...d.php?t=417872
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-16-2017, 06:49 AM   #4
chazdo2
Thanks a ton. I will get the alternator model and get back to you. Really appreciate the help!
Old 06-16-2017, 08:46 AM   #5
chazdo2
Its a delco remy alternator 1101 490 120 A it has a connector with four leads inside
Old 06-16-2017, 01:18 PM   #6
toolboxchev
Re: 1971 chevy pu alternator problem
Check the electrical section and do a search within 67-72chevytruck.com. You will find answers to your questions with some reading. VetteVet is the resident electrical guru and is always lending a hand to someone. Great people here.
toolboxchev is offline   Reply With Quote
Old 06-16-2017, 06:44 PM   #7
chazdo2
thanks you guys are the best! I think ill pm vette vette
Old 06-16-2017, 07:24 PM   #8
chazdo2
got the American auto wire kit its great!!! When I was ripping and tearing I think I threw out the voltage regulator not knowing what it was. Not sure how to wire it back in
Old 06-16-2017, 11:07 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I just replied to your PM and included the link above which should explain all you need to know to wire in the CS alternator.
VetteVet
