Old 06-15-2017, 11:14 PM   #1
t300
silverado fuel pump/sender fitting
On a factory in-tank pump feed and return from 2001 silverado, can I use either of these fittings *on the sender*?
https://www.summitracing.com/int/par...4123/overview/
https://www.summitracing.com/int/parts/tnk-640853
I used the Russel part on my fuel rails and worked fine, and I liked the threaded retaining cap. Now, I'm going to ditch the inline Walbro and sink the 2001 pump into a rear mount tank. Will the Russel piece work right on the sender as well or do I have to use something like the Tanks Inc fitting?
t300 is offline   Reply With Quote
Old 06-16-2017, 06:11 AM   #2
72MARIO
72MARIO's Avatar
Re: silverado fuel pump/sender fitting
They are the same as fuel rail. The emissions line is diffirent. I used the MU1416 pump module it only has one electrical plug for the pump no emissions electrical connection.
The all aluminum fittings are the only ones I will use on my trucks. Amazon.ca had the 3/8 fittings for. $18 last week.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
