06-15-2017, 11:22 PM | #1 |
Are 81+ Bedsides a direct bolt on for a 76 SWB fleet?
Are 81+ Bedsides a direct bolt on for a 76 SWB fleet? I'm wanting to convert our truck to dual tank. I found a pair of bedsides, but they are for an 81+. Will these line up with the existing holes in the 76 floor and head board?
Thank you, Wes
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
06-16-2017, 12:28 AM | #2 |
Re: Are 81+ Bedsides a direct bolt on for a 76 SWB fleet?
I think they will bolt up, but the humps in the floor to clear the fuel necks might not match up. I'm not for certain, but I think there is 2 diffrent size humps?
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
06-16-2017, 12:59 AM | #3 |
Thanks for the information Jaysonb. Can anyone congirm about the fuel neck humps?
Posted via Mobile Device |
06-16-2017, 07:39 PM | #4 |
I think the humps are the same. Most places list one replacement floor for 73-87. The 81 will have fuel filler doors and the filler necks will be different.
06-16-2017, 08:13 PM | #5 |
At the body shop.
Yes, but the gas neck hump is different.
Have 84 1/4's on a 73 floor.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 06-16-2017 at 09:26 PM. Reason: Pics- |
06-16-2017, 09:31 PM | #6 |
At the body shop.
Pic came out upside down. But you get the idea.
" That didnt make it any newer " " Dont antique the equipment " |
06-16-2017, 09:38 PM | #7 |
twinturbo10, Kqql it, thanks for the information and the pics. Doesn't look too bad as long as you do the mod before painting the bed.
BTW, did the later fuel neck work with the earlier tank?
06-16-2017, 09:52 PM | #8 |
At the body shop.
I don't know actually.
Put a fill neck in the floor from the early 1/4 panel. Only real issue I could see is the newer fill necks are 1-5/8 and the older tank fills are 1-1/2.
06-17-2017, 03:59 PM | #9 |
kqql it, thanks for the pics, they help visualize it.Changing tanks isn't a big deal, but was hoping to be able to put it off until I do a LS swap.
