Old 06-16-2017, 09:51 AM   #1
ebaby35
Installing steering gear box
Ok I picked up from a junkyard a 1990 c1500 gear box for my 1964 chassis with a 85 suburban front-end. On the c1500 it was located on the inside of the chassis but on my chassis it's too big to go on the inside due to the c channel. Is there any modifications that I need to do or am I mounting wrong. I was under the impression that a 1990 would work.
ebaby35 is offline   Reply With Quote
Old 06-16-2017, 10:30 AM   #2
Mathew21
Mathew21's Avatar
Re: Installing steering gear box
I always thought the cutoff year was 87' for the steering box unless you get it from a Suburban or a OBS Crew cab then it would be up to 91'.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 06-16-2017, 10:43 AM   #3
ebaby35
damn your probably right
Old 06-16-2017, 11:25 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yep, up to '87 from a truck, '91 for Suburban
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-20-2017, 08:03 PM   #5
ebaby35
Ok found another one it's a 91 suburban but it's a 3/4 does that matter
Old 06-21-2017, 10:33 AM   #6
chevy_mike
chevy_mike's Avatar
Hopefully someone will chime in but I "think" they are the same as far as the box and pitman arm goes. I am fairly sure the tie rods are different but you're not using those. You might search on RockAuto and compare the 1/2 ton and 3/4 ton part numbers for a steering box. That would help confirm the box. I am not as well versed on the total difference between the 1/2 and 3/4 ton items.
Old 06-22-2017, 10:38 PM   #7
ebaby35
Ok I got a 91' suburban gear box today and tried to bolt up to 64' chassis. Is there a adapter plate so it rests flat ag ain't the frame? And can I use the same holes?
Old 06-23-2017, 07:20 AM   #8
The Rocknrod
Moderator
The Rocknrod's Avatar
Yes there is: http://www.67-72chevytrucks.com/vboa...d.php?t=332923
Old 06-23-2017, 10:47 AM   #9
chevy_mike
chevy_mike's Avatar
Yep, Captianfab's adapter is the only one I use. I have done two trucks with them. It will require drilling a few holes. It comes with a template which makes it really easy.
Old 07-04-2017, 08:13 AM   #10
luvbowties
luvbowties's Avatar
Thumbs up Re: Installing steering gear box
My congrats to ChevyMike for an excellent "run" of pics on installing & using that adapter from beginning to finished project. Thanks from many who hopefully will look at your post when they install ps..
Sam
luvbowties is offline   Reply With Quote
Old 07-05-2017, 02:06 AM   #11
ebaby35
Thanks for the pics I just recieved my bracket from captainfab. The stuff is great the detailed pics and template. Thanks for the help and posting your pics of your Install.
