Old 10-23-2003, 10:17 AM   #1
sactoC10
71 DELUX
sactoC10's Avatar
stock vs adjustable panhard
It seems that the catalogues indicate that drops over 5" require replacement of the stock bar with an aftermarket adjustable one, correct?
I've also heard of and read about people who can visually see the rear of the truck moved over 1-2" before replacing the bar. Mine is down about 4" right now and there is no evidence of any shift.
So what really determines if it needs to be changed?
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 10-23-2003, 10:47 AM   #2
72longbed
72longbed's Avatar
Sacto,
I just went through this with my C-20. IMO what dictates the need for an adjustable bar would be the position of the rear axle at final ride height. If you find that the rear is off center when the truck is at rest, then you may want to correct this by installing an adjustable panhard bar. Each truck will be different at rest because of suspension modifications, but one thing is for sure, as the rear axle goes through it's normal up and down travel the amount of left to right movement is magnified. Therefore I feel that having the axle centered at normal ride level is optimum.
Just my opinion.
72
72longbed is offline   Reply With Quote
Old 10-23-2003, 01:27 PM   #3
Physh1
I'm not too familiar w/ your body style trucks but any panhard bar need to be ideally horizontal to the ground at ride height to minimize axle shift. If you bar is not level you would be best to change it as the more it is off the worse the shift the axle goes through during suspension travel.
Cameron
Please visit http://www.WhosNextRacing.com & http://www.FSCustoms.com
2000 Chevy Crew Cab Dually, 1994 Chevy ECSB 4x4, & 1983 GMC Sierra Classic
Physh1 is offline   Reply With Quote
