06-16-2017, 09:35 PM | #1 |
TBI Has Anyone Used These
TBI Has Anyone Used These Im Going To Go Tru My TBI Check The Injectors And Clean It Up, I Was Told That The Fuel Pressure Should Be 9 To 13 PSI
Let Me Know If Anyone Used These Parts OK Thank You For Any Reply Harley03joe This fitting will replace the TBI inlet fuel nut and provide a place for your fuel pressure gauge attachment. Dimension of attachment is 1/8" NPT. Fitting comes with special OEM type teflon washer. You will be able to use your OEM fuel line. Part # 62-FP 86'-95' TBI Fuel Pressure Adapter Fitting This Tbi Adjustable Regulator is needed for stock and modified GM tbi engines. At 3/4 to WOT the computer uses a fixed program for max power. Therefore,since it is not reading the A/F ratio you may need more or less fuel for maximum power. This regulator let's you change what the computer can't. Includes installation gaskets and instructions. Part # 62-FR 86-95 GM TBI Fuel Adjustable Fuel Regulator (with gaskets) 86-95 GM TBI Fuel Pressure Gauge Includes installation gaskets and instructions. Part # 62-PG 86-95 GM TBI Fuel Gauge Last edited by Harley03joe; 06-16-2017 at 09:45 PM. Reason: words |
06-16-2017, 10:12 PM | #2 |
Re: TBI Has Anyone Used These
I have, multiple times. The adapter requires slight modifications to the hard fuel line , (just a slight tweak to the bend). One word of advice: keep a close eye on that fuel gauge, mine failed and puked gasoline all over the hot engine while driving. Scared me enough to install a gauge that used an electric sending unit.
06-16-2017, 10:18 PM | #3 | |
I Will Check The Gage Often And Might Just Plug It Off After Its Installed What Did You Think About This Item Does It Work Ok ?? And Thank You For The Fast Comeback Harley03joe This Tbi Adjustable Regulator is needed for stock and modified GM tbi engines. At 3/4 to WOT the computer uses a fixed program for max power. Therefore,since it is not reading the A/F ratio you may need more or less fuel for maximum power. This regulator let's you change what the computer can't. Includes installation gaskets and instructions. Part # 62-FR 86-95 GM TBI Fuel Adjustable Fuel Regulator (with gaskets) |
06-17-2017, 01:15 AM | #4 |
06-17-2017, 07:56 PM | #5 |
Hope this helps |
06-17-2017, 10:57 PM | #6 | |
06-19-2017, 03:50 PM | #7 | |
06-20-2017, 12:11 AM | #8 |
06-20-2017, 11:09 AM | #9 |
I will start by saying - I have not used this gauge. I have the handheld gauge which I put into the line with an adapter. Its sort of a pain to use - as you have to go under the truck, loosen the fuel line, put adapter in, check pressure, then remove the adapter again. I also have dual exhaust which makes that space pretty cramped to work in.
But I would rather do that vs having the gauge in the line all the time right on top of the engine. If you are running a stock engine, I don't think you really need this - that's my $0.02. Probably fine with the stock regulator psi. But if you want to modify the engine, then its not a bad idea. |
06-21-2017, 01:54 AM | #10 | |
Going To Work On It Again In The Morning Thanks For Your Input Harley03joe |
06-21-2017, 01:57 AM | #11 | |
Boy I'm Trying To Get The Fuel Line Lined Up Now Its Not As Easy As It Looks Going To Work On It Again In The Morning Thanks For Your Input Harley03joe |
07-02-2017, 03:06 AM | #12 | |
And About FhotoBucket I Left Them & Went With Flicker Harley03joe |
