06-16-2017, 11:34 PM | #1 |
short bed frames the same?
So I have some frame damage on my 1987 Silverado 2wd short bed. I have found a 1978 Scottdale short bed 2wd for cheep so my question is are the frames the same between the two years?
Thanks in advance |
06-17-2017, 05:22 AM | #2 |
Re: short bed frames the same?
Yes its the same body style but if one has a gas door and the other is cap only,You have to change out the filler neck to match the bed your using.
06-17-2017, 07:18 AM | #3 |
The front of the frames are different 81-87 they are open angle cut and the 73-80 they are closed not a big deal and also the cab mounts are different just make sure you use 78 cab mounts other than that pretty much the same
06-17-2017, 08:43 AM | #4 |
Yep, Jeff nailed it. You can cut off the front rounded portion of the frame horns. New 73-80 body mounts and your set.
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
06-17-2017, 09:00 AM | #5 |
The 87 frame will have provisions for the e brake cable to run along the driver side. If you want the correct frame, I will trade you frames. I have an 84 that's in nice shape.
06-17-2017, 10:41 AM | #6 |
If I'm not mistaken the trucks are almost identical 81-87. I have an 85 c10 and have used a lot of junk yard parts from those years without any problems
06-17-2017, 01:44 PM | #7 |
81-87 are almost identical but he's comparing 78 to 87
06-17-2017, 02:53 PM | #8 |
my bad! misread.
06-17-2017, 06:32 PM | #9 |
I agree on the frame horn differences, but I think the core support mounts are in different spots too.
06-17-2017, 09:33 PM | #10 |
nope . i have 2 trucks with 81-87 bodys on 73-80 frames . other than said front frame horns / body bushings / e-brake stuff it was a bolt on swap .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
06-19-2017, 12:09 AM | #11 |
One silly difference I noticed was that the fuel sending unit grounding hole was on the inside of the frame-instead of 81-87 frames where its on the top of the c-channel of the frame. I discovered while rebuilding my project truck it is an 86 cab on a late 70's 4x4 shortbox frame.
06-19-2017, 07:29 AM | #12 |
Good thing the 73-80 frames are a little thicker then the 81-87
+ all the all ready listed.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
