Old 06-17-2017, 02:07 PM   #1
mosel70
Why is lower rad hose a higher temp?
'70 C10, 402. I have all new cooling system components to include Summit's water pump SUM-312461
Water Pump, Mechanical, High-Volume, Iron, Natural, Chevy, Big Block, Long, Each
I've noticed my upper rad hose from T-stat to upper/drivers side rad is 10-20 degrees cooler than the lower/pass side hose to water pump.
Q. Does that mean coolant is flowing OUT of the water pump to the rad and is the more accurate temp?
mosel70 is offline   Reply With Quote
Old 06-17-2017, 02:47 PM   #2
MagmaJct
MagmaJct's Avatar
Re: Why is lower rad hose a higher temp?
Interesting.
Where does your heater flow to?
Apparently, at least on the SBC, for manual transmissions the heater core returned to the pump. On automatics, the heater core returned to the cool end of the radiator.
I suppose if the thermostat was regulating the coolant around 185F, which is a common aftermarket temperature, and the heater was returning hotter coolant to the radiator, then that might explain your inverted readings.
Of course, if your fans are off, this would make a lot of sense, as there'd be very little cooling taking place.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 06-17-2017, 03:08 PM   #3
Wrenchbender Ret
That is weird. I wonder if you got a water pump for a Serpentine belt. It turns in the opposite direction.
Wrenchbender Ret is offline   Reply With Quote
Old 06-17-2017, 03:31 PM   #4
Alex V.
Alex V.'s Avatar
Hmm! From doing a lot of work on front-wheel drive cars that requires letting the engine sit and warm up, I can say the cooling capacity of the radiator even without fans running is enough to maintain coolant temp for as much as 10 minutes before a fan needs to kick in for the first time. That is to say, even with an elec. fan setup I can't imagine the lower hose would be the same or higher temp. than the upper if the system is full and it's flowing the right way, regardless of heater hose routing.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 06-17-2017, 04:16 PM   #5
MagmaJct
MagmaJct's Avatar
Perhaps. But consider the thermostat is probably regulating the coolant leaving the the engine around 185F. But if the heater core is dumping into the cold end of the radiator, it could potentially be increasing the temperature of the coolant entering the pump.
The original poster could also take a temperature reading of his heater hoses to confirm my hypothesis.
Old 06-18-2017, 04:15 PM   #6
57taskforce
All about them K’s
57taskforce's Avatar
Exactly what I was gonna say. Make sure you don't have a reverse rotation pump.
Tyler
57taskforce is offline   Reply With Quote
Old 06-18-2017, 04:35 PM   #7
hjewell2
hjewell2's Avatar
I have a 1980 Malibu SBC and it does the same thing. when I put the thermal gun on the T-stat housing it says 212* with a 180 T stat. the hose says 185*
Lower hose 198* radiator 177* just before going to bottom outlet. top of rad by inlet reads 189* soooo I thought about this for a little bit. the gun is picking up heat from the engine block, the fan is blowing air right back at the block and going around it causing the readings what they are, feel free to chime in and correct me. as for my 70 C10 never checked it never gave me reason to, stays at 170* all day. now the Malibu is giving me fits with over temping that's why I checked it.
hjewell2 is offline   Reply With Quote
Old 06-18-2017, 08:25 PM   #8
hjewell2
hjewell2's Avatar
Thumbs up Re: Why is lower rad hose a higher temp?
Originally Posted by firedemon View Post
with those meters you need to be exactly the same distance from what your measuring or it will pick up temps from other sources especially the further you are away from what your measuring
yup what I figured
Old 06-18-2017, 08:47 PM   #9
davepl
davepl's Avatar
Mine has 2 lasers that intersect so you know you're at the "right" depth when they overlap and appear as a single dot. Handy.
Assuming your measurements are right, gotta be a reverse rotation water pump! Wild if true, never seen one run.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-18-2017, 11:48 PM   #10
57taskforce
All about them K’s
Only reason I thought of it was I had a cpi 4.3 in an s10 blazer that AutoZone gave me a standard instead of the correct reverse pump. I had a similar issue with the exception that it ran 15-20* hotter than before I replaced the pump.
Tyler
Old 06-19-2017, 01:29 AM   #11
mosel70
Hey, I appreciate all the replies. Helpful. Thanks!
I have a 3-core Mishimoto rad and dual electric fans. I'm chasing an overheat problem where temps only increase at idle, not while driving. It eventually goes into the red and starts idling rough.
I had my temp gun the same distance away from both top and bottom hoses, even shot the temp from below the truck at same distance. Bottom hose always hotter than top hose. In the pics below, the hose from the pump goes to the hose on top on the firewall. Hose below it on firewall goes to intake manifold. I readjusted idle mixture screws on Edelbrock 750 carb to ensure it's not too lean, still overheating. I'm perplexed. Last two remaining theories is total timing is too retarded or the TH400 torque converter is overheating. The trans cooling lines go to the radiator. Engine overheats whether or not the A/C is running. The gauge in middle red is 216 degrees on top hose and 226 degrees on bottom hose and that's where it starts idling rough. Once I start driving at highways speeds it stays in the red or barely comes out of the red.
I removed the 180 degree T-stat and no changes noted, same issues.
I'll take temps of heater hoses this week and will post.
Oh, yeah, the pump direction. My understanding is that V-belt pumps are clockwise (which I have) and serpentine belts are for counterclockwise pumps. So I'm assuming (correctly?) that clockwise causes the pump to pull coolant in from bottom rad hose. But should mean cooler rather than hotter coolant which it's not.
Old 06-19-2017, 01:37 AM   #12
mosel70
According to Vintage Air diagram, I have the heater hoses correctly connected.
Old 06-19-2017, 08:31 AM   #13
67 chevelle
67 chevelle's Avatar
could be , and that would solve your overheating mystery
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 06-19-2017, 10:26 AM   #14
67ChevyRedneck
67ChevyRedneck's Avatar
Do you have a better pic of your shroud? I had a similar problem with my mustang. I've found that "flat" style shroud actually blocks air from flowing through the radiator at highway speeds.
Almost all stock fan shrouds are 2-3" away from the radiator and are dished to let the air flow through. With those flat aluminum shrouds they're only 1/2" - 1" away from the radiator and being flat, they act as a wall creating hot spots inside the radiator because the air can't flow through.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-19-2017, 11:29 AM   #15
weq92f
weq92f's Avatar
Hadn't thought of that ( the nice looking stainless steel "shroud" blocking regular at-speed air flow and causing problems ).
The argument seems to stand in my thinking anyway. So, the solution then would be...?
...Anything that allows free air flow is also going to diminish the CFM the fan(s) is/are capable of pulling through the radiator. It's a pressure thing. Allowing free flow is going to not allow as much negative pressure under the shroud during slow speed fan operations.
What gives? What is a nice compromise here between functionality and good looks?
Would a flapper over a vent hole on the "inside" of the engine bay/radiator shroud do the trick? That is, allow pressure when pulling from the shroud side, but also allow free flow through at speed?
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-19-2017, 01:27 PM   #16
cleszkie
cleszkie's Avatar
My dual electric fan shroud covers the entire radiator core. But it does have multiple rubber "flaps" around each fan that allow air to pass through the shroud at highway speeds. It was made specifically to fit our trucks. I bought it through Old Air many years ago.
cleszkie is offline   Reply With Quote
Old 06-24-2017, 10:56 PM   #17
mosel70
Hey, I really like those!
But, the PO put a GMC grill on and the hood latch mechanism is more rounded on the aft side, different that for Chevy Grills.
I don't any of these online for '70 C10 GMC grills. Do you know of any online sources?
Old 06-25-2017, 07:04 AM   #18
HO455
Post Whore
HO455's Avatar
Just a couple thoughts. Is it possible at idle that much of the air is just moving in a cycle from the back of the fans over and under the radiator into the front of the radiator and the air is getting hotter and hotter when the truck is not moving? Are both fans turning the correct direction? Is the pump turning at the correct speed? Do you see good coolant flow in the radiator? When you are looking into the radiator and the thermostat is open as you Rev the motor the coolant level should drop as it is sucked into the pump.
RIP Bob Parks.
Old 06-25-2017, 11:41 AM   #19
leftybass209
leftybass209's Avatar
Since this got back up to the top, I thought i'd share some information about coolant temps.
This is slightly generalized and hinges some conditions like timing which can negatively increase temps due to a mechanical disadvantage.
Engines like to run hot. The hotter the engine, the more complete the combustion process will be, the more power the engine will make and the cleaner the tailpipe emissions will be. A SBC is completely fine at 220. If it's not puking coolant, it's running fine. The cooler you run the engine, the worse the combustion process is and ultimately your gas mileage.
If you aren't boiling coolant, it's running just fine. Water boils at 212 degrees without pressure. The reason for the closed loop coolant system is to increase the temperature that the coolant boils, thus increasing its ability to cool the engine.
leftybass209 is offline   Reply With Quote
Old 06-25-2017, 11:57 AM   #20
MagmaJct
MagmaJct's Avatar
You are not mistaken. What we are looking at is "thermal efficiency". Pistons move due to the increasing pressure in the combustion chamber. With that rapid increase in pressure comes heat. (Or is it the pressure come with heat?) Anything that absorbs that heat will also reduce the pressure.
Coolant that's too cold will "take energy away" from the process, reducing thermal efficiency. In addition to that, raw fuel vapor will more readily condense on cylinder walls, diluting the engine oil causing accelerated cylinder and ring wear.
I once did work on an old Mercury Cougar. The engine wouldn't warm up. Turns out it had one of those "fail safe" thermostats that ratchet in the open position if the engine were to overheat. The problem? The engine never overheated, the thermostat just decided to stick open.
More recently I was replacing a thermostat in one of my vehicles. The parts guy at Autozone asked me if I wanted a "fail safe" thermostat. I told him "no" and I commented that I don't trust them. To which he responded: "Yeah, neither do I. In fact, I don't even have a thermostat in my truck, we're in Arizona, we don't need them here."
To which I responded: "Oh-kaaayyyy"
I used to debate part jockeys in my younger years. Then I realized people like him are incapable of growing intellectually. (They learn something, but are completely unwilling to "update" their beliefs when new, more accurate, information is presented to them!)
Then there was the parts guy in the late `90s who told me not to use synthetic oil in new engines because "the pistons will fly off!"
