06-18-2017, 10:04 AM | #1 |
Anyone have Vision wheels on their square?
Looking at these wheels. The price is great https://m.summitracing.com/parts/vsw-1438873gmml6
06-18-2017, 10:21 AM | #2 |
Post Whore
Re: Anyone have Vision wheels on their square?
I've seen those style wheels on squares..vision wheel is just up the road from here
06-25-2017, 12:02 AM | #3 |
I was looking for some gray wheels when I stumbled across this thread. So I went to the Vision website to take a look. I was interested in the staggered look particularly--20x8.5s front with 20x10s rear. With this setup, the common suggestion is to go 4.5" backspacing on the front and 5.5" backspacing rear. Well, Vision has the fronts in those size but for the rear, they only offer 20x9.5" wheels with either a 5.25" or 5.75" BS . So that leaves me with the question, which backspacing should I use for the widest possible tire, give the best look and still tuck. I run 275-45-20s now, hope to eventually push 305s or 315s. My rear drop is somewhere in between 6 to 7" on a '86 short wheel base. I'm not sold on any particular wheel just yet. But was thinking, what if another wheel I do like comes only in the same type configurations? Any thoughts?
Vison Wheels http://www.visionwheel.com/wheel/6855/2831/
Everything that can be counted does not necessarily counts; everything that counts cannot necessarily be counted--Albert Einstein Last edited by Jay2Cor517; 06-25-2017 at 12:27 AM. |
06-25-2017, 10:47 PM | #4 |
For the 20x9.5 I would say the 5.25 backspacing which will put the tire and wheel a 1/4" more to the inside. Tucked a 1/4" more is what I meant. It will let you run a little bit more taller tire with a little bit more sidewall bulge and not rub. But of course that would still need to be verified.
06-27-2017, 02:16 PM | #5 |
18x8.5 w 245/45/18 up front 18x9.5 w 275/40/18 rear
65 Chevy C10 Short Fleet BBW 6.0L/4l80E 68 Chevy C10 SWB 6.0L/4L80E 84 Chevy C10 SWB 5.3/4l60E QA1 Suspension |
06-27-2017, 10:08 PM | #6 |
Thanks Tetanus for the input. And MS2335 that's a good looking truck, is it yours?
Everything that can be counted does not necessarily counts; everything that counts cannot necessarily be counted--Albert Einstein |
06-28-2017, 05:29 AM | #7 |
Thanks, yes I is my daily driver
06-28-2017, 08:17 AM | #8 | |
Clean fricken truck by the way Posted via Mobile Device |
06-28-2017, 09:42 AM | #9 | |
thanks I haven't tried the rears up front but with the 5.25 backspacing they should work alright. If you have the 1.25 rotors on the front, you have to run a shim on it or remove the dust caps and clearance the hub. I have the 8.5 on front with the 5.12 backspacing (I think that is it), they sit in about an 1 or so under the fenders. I run a 5/16 shim from autozone with longer lugs for hub clearance.
07-01-2017, 04:13 PM | #10 |
Are you having to run a shim now? Or are you saying if you tried the rears upfront?
07-02-2017, 12:43 AM | #11 |
US Mag makes a version of that wheel in 20 X 10...its called the rambler......
http://us-mags.com/rambler-u111-w-6133.htm
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
07-02-2017, 01:08 AM | #12 | |
