06-18-2017, 01:23 PM | #1 |
How to remove the glove box latch??
My truck (84 k10) the glove box door is missing the latch where you turn it to open the glove box it has the hole but no latch went to the junkyard and snagged up a whole used door....but cant figure out how to get the latch to separate from the door. I just need the latch the junkyard door is rusted and mine is in better shape. thank in for the help.
06-18-2017, 01:38 PM | #2 |
Re: How to remove the glove box latch??
-Cody |
06-18-2017, 02:40 PM | #3 |
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
06-18-2017, 05:05 PM | #4 |
Awesome thanks alot
06-18-2017, 06:36 PM | #5 |
Perfect timing. I was just going to start a thread on this!
