![]() Join Date: Nov 2011
72 Custom/20 Deluxe Badge placement?
Can anyone answer this question? I have 72 fenders without pre-drilled holes for badges. I need to figure out exactly where to drill holes. I suppose I am going to have to take the fenders off to get the nuts on the backside, unless someone has a better idea. Anyone have a fender laying around that can measure from the top edge of the fender down to where the first hole should be drilled and from the door edge in?
Dale - ApacheIvan 1972 Chevy Custom/20 Custom Camper Highlander http://67-72chevytrucks.com/vboard/s...d.php?t=740479 Original Owner ** Do you have a 1972 Plaid Pickup?** |
Re: 72 Custom/20 Deluxe Badge placement?
No one can help? I would pay someone to make me a template. I just need to know where to drill holes in my fenders:P
![]() Join Date: Apr 2014
Barrel nuts are your friend, that way you don't have to take the fender off.
Mike |
#4 | |
Maybe some gorilla glue ![]()
Dale - ApacheIvan 1972 Chevy Custom/20 Custom Camper Highlander http://67-72chevytrucks.com/vboard/s...d.php?t=740479 Original Owner ** Do you have a 1972 Plaid Pickup?** Last edited by ApacheIvan; 06-20-2017 at 05:55 PM. |
Even better, double-sided 3m tape
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
I worked at the GM Truck plant for 33 years, when we had to replace a emblem instead of taking everything apart we used barrel nuts. The are a time saver and hold well as long as you cut some threads on brand new emblems. I just bought 50 of them because I couldn't find them in smaller qtys just so I can save some time.
Mike |
Does anyone have the 1967-1972 Chevrolet Truck Factory Assembly Manual? I think there is a picture in there that tells me exactly where these badges go. I do not want to drill holes in the wrong place
#8 | |
![]() Join Date: Aug 2013
You can get barrel nuts at large hardware stores which work good Also if the inner fender hardware is not to rusty , you can drop it down pretty easily and get behind the fender, to find exactly where they go. Providing they are original custom deluxe fenders |
#9 | |
Here ya go
Dude, you rock! That should get me close enough...Thank you so much!
![]() Join Date: Oct 2009
Close enough can usually result in something looking not quite right. Recommend go with assembly manual specs, believe they have very detailed pics for badge placement. Sorry I'm not at home so can't go grab this and post it for ya dale.
#13 | |
![]() Measure twice, drill once ![]()
#14 |
No scottsdales in this era. You may not have received a reply to the assembly manual request because they are an absolute pain in the butt to find stuff in - it's just a pile of pages - and what you need will always be on the opposite end of the book from where you start looking. It's worth buying one. Someday, I'm gonna index one.
#15 | |
#16 |
If it were me, I wouldn't worry about it to much
Really, we're talking about 40 yr. old chevy trucks here Unless you are doing some white glove restoration or something I doubt anyone will notice if you are 1/16" off But that's just me Cmon guys, the guy doesn't get any responses to a simple emblem question. Then we scare him that he might mess up his emblems , like it is brain surgery For the record I know those fenders have never been changed |
#17 | |
#18 |
![]() Join Date: Feb 2009
If you still need the measurements say the word. My fenders are hung up without the badges.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#19 |
Ok, one side done. Close enough!
#20 |
Just got back to the house, didn't see any follow-up on this. Sorry took so long. Included the Custom Camper emblem placement since I think you may need that also(?) The Deluxe page only shows how to anchor off the Custom Holes, didn't find the page for the Custom holes yet. 0.82 below the left justified Custom hole and then 2.81" to the right of the left Deluxe hole.
#21 |
Thanks Jocko, I am glad I got the measurements from the top of the fender. That diagram would not have given me enough information. I think the CC diagram will be helpful when the badges come in. I am only .08 off my Deluxe badges.. instead of .82 I went. 1.0 I think they came out ok. Used Gorilla Glue on the posts. Gorilla glue expands as it dries, I had to keep wiping the drips, but within 2 hours it was done. It will take quite a bit to get them off, but when I am ready to paint it I can get them back off and I may take the fenders off anyways and fasten them correctly.. I appreciate all your effort!
