Old 06-19-2017, 03:49 PM   #1
Malo83
Cruzzzn' Vet
Malo83's Avatar
WalMart MAXX 78S
Just put in this battery, 650 CCA, replacing an Interstate Mega Tron II also 650 CCA which was starting to act up but now with this Heatwave sweeping thru central Cali, 109+ it couldn't take the heat, anybody else running this battery and how long has it lasted?
Malo83 is offline   Reply With Quote
Old 06-19-2017, 06:39 PM   #2
Dead Parrot
Re: WalMart MAXX 78S
Running an Energizer Max from Sam's Club, 795CCA, with a 4/14 manufacture date.
You could have lost the battery lottery, that is what the warranty is for. My luck is the battery becomes iffy about a year before the end of the warranty and about two years after the receipt got lost.
Dead Parrot is offline   Reply With Quote
Old 06-20-2017, 12:35 AM   #3
Gregs71
I have used that battery several times and regularly get about 5 years out of it give or take. No complaints.
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 06-20-2017, 02:20 AM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
Thanks,
Old 06-20-2017, 06:10 AM   #5
D13
D13's Avatar
3 weeks on one.
10+ years in the diesel. Goes flat if let sit 3 months, but other than that, keeps on fring it up.
Usually they fail quickly or good for at least 7 years, given reasonable charging rate. Don't ever kill it - first time a battery goes flat it permanently loses 15-20% of its capacity.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 06-20-2017, 08:32 AM   #6
only126db
Batteries today are hit and miss. I ran a WM batteries with no issues in a couple different vehicles for 4+ yrs but then people say they crap out in days.... I now have an Autocraft Gold which has just crossed the 3 yr mark, it tests down 100 amps from it's rating but still keeps kickin...
only126db is offline   Reply With Quote
Old 06-20-2017, 09:10 AM   #7
Warrens69GMC
Warrens69GMC's Avatar
johnson controls and exide make about 90% of the batteries that are sold in the united states, and even some brands you thought made their own (interstate)
Diehards (sears), Everstarts (walmart), Surestarts, etc, etc
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 06-20-2017, 05:19 PM   #8
tucsonjwt
I bought one for the Cav and it was dead when I installed it. I took it back for a refund and got an Interstate from Costco. Costco has their Interstate batteries stocked every month by the Interstate truck, so I think they are "fresher." Also, Costco has a 3 year replacement warranty.
tucsonjwt is offline   Reply With Quote
Old 06-20-2017, 05:32 PM   #9
Tom
driving is in my blood
Tom's Avatar
Battery is a battery. They all last about the same amount of time when comparing similar types.
Old 06-21-2017, 01:32 PM   #10
Malo83
Cruzzzn' Vet
Malo83's Avatar
WalMart batteries are replenished weekly than monthly, the date tag on my battery says 6/17
Old 06-21-2017, 04:54 PM   #11
wilkin250r
wilkin250r's Avatar
And from the research I was able to find, Johnson Controls is generally considered the better of the two, and last I checked WalMart MAXX batteries are made by Johnson Controls.
I've run several Maxx batteries, and I've had great luck with them. I'm not too far from that central Cali heat, only a little higher altitude so when you're 109, I'm only 101. But when you're 35 degrees, I'm -10. It gets cold cold cold here.
My last MAXX battery lasted 8+ years with daily use, and my current is 4+ and I am trying my best to kill it. I've developed a weird problem in my F*rd, when it rains I need to crank the engine for (no joke) 5 solid minutes. And that battery does it, it cranks and cranks and cranks and cranks. It has treated me VERY well.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 06-21-2017, 07:11 PM   #12
Jrgunn5150
I have one, tag of 4/14.
I've run it flat half a dozen times, still takes a charge and fires the Ole 400 off, when she'll fire anyways.
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
