pump to carb steel line for an L6
Greetings
I need to replace the 'reverse flare' nut at the carb on my 1971 C10 250L engine. The carb is stock Rochester 1 barrel. Can someone recommend a complete replacement line (pump-carb) or the appropriate tube flare tool for this fix. The tube diameter is 3/16" but I'm not sure what angle the end is flared too. It appears the flaring tools come in a couple different angles. thanks John |
#2 | |
Re: pump to carb steel line for an L6
![]() Join Date: Oct 2012
Try Inline Tube for a new one.
I used their carb to pump fuel line on my 72 350, fit perfect, good quality. Think it was about $25, ready to bolt on. https://www.inlinetube.com/
Larry 84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles. 72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold) "It's a sorry man who can't find his wife a good job" |
Like Hoover fish stated it's probably cheaper just to get a
New line and replace it outright. If you do want to purchase a kit on your own here's the one that I have. It can do single or double wall flares but does not do any actual bending of the tube. I have no idea the cost of this kit these days but I'm sure you can look it up. Steve weim55 Colorado Last edited by weim55; 06-20-2017 at 01:20 PM. |
One more pic, this shows the model and brand at the top. The brand is Ridged.
THANKS for the quick replies.
I ordered a new line from inlineTube.com Only $25. Will the 'standard' 45 degree flare tool work or is a "double flare" tool needed? |
![]() Join Date: Dec 1999
Everything I have is double flare.
When you get your tube from Inline Tube will you post a picture of it? Have they shipped it yet? I have a 1968 with a 250 and have bought 2 pump to carb lines that don't work. It makes sense they don't work...because they are all listed a fitting 67-70....even on Inline Tubes site. They look like they will work with a 67 but the carburetor is different in 68,69 and 70. The fuel inlet faces a different direction on the carb. |
#8 | |
The 71 inline engine carb fuel fitting faces the radiator. Like usual the nut at the carb is buggered up. People don't have sense to use proper tools. ![]() |
I just got an email from Inline Tube saying the one I ordered for 71-72 250 has shipped. Hopefully yours has too.
I opened a NOS rebuilt carburetor today and found 2 copies of this inside. ![]() I still think they are doing it the wrong way by not using a line wrench. |
#10 | |
![]() Where, pray tell did you find an NOS carb? I just got a tracker for the fuel line. |
Got the line today and when I first saw the box my reaction was ........... hmmmm....... that looks too small.
But, all is good............. just had the tiniest of tweaks to get the nuts to thread in properly. I did have to really crank the nuts to get them leak tight. The quality the fuel line and fittings is excellent. This is roughly the view angle when it's in the vehicle. The carb connection faces forward on the single barrel Rochester carb. ![]() I had previously wrapped aluminum foil around the pump-carb hardline to help minimize fuel boiling after a hot shutdown. I will probably do the same heat shield treatment on the new line. I may use real heat shielding fabric this time though. Maybe use propane burner shielding blanket that you can get a the big box hardare stores. The fuel line is only ~3" above the exhaust manifold and with the alcohol rich fuel it can boil after a hot shutdown. Last edited by Carl Spangler; 06-28-2017 at 07:22 PM. |
I got mine a couple days ago. Just held it up to the motor today. Fits my 1968 perfect too.
I really wish they would get their information fixed so others with 68,69 and 70 don't buy the wrong one. I don't think my fuel line runs over the manifold where there is not something between the manifold and the line. I have the power steering bracket and the metal heat riser piece that attaches to the manifold and channels hot air up to the air cleaner. |
#13 |
Fuel line runs right over the exhaust manifold. When the engine shuts down the heat from the manifold can boil the alcohol rich fuel which can cause all kinds of grief.
