06-20-2017, 01:20 PM | #1 |
56" springs for rear with 2" lift?
I Installed 2" tuff country EZ springs in the front of my 71 blazer but still have the stock 52" springs on the rear with an add a leaf to level it. I would like to put a 56" spring in the rear to give a softer ride but don t want to do a 4" lift with a shackle flip like most of the threads out there. I would like to get a 2"-3" lift out of the 56" spring. How would I do this? I have no clue if mounts need to be moved or if I need longer shackles or etc? would appreciate any advice.. Thanks, Mike
06-21-2017, 12:30 PM | #2 |
Re: 56" springs for rear with 2" lift?
how many leafs do you have now?...i have the same lift in front ,but my rear springs have seven leafs,so i have no idea what spring i have ...probably the one you want because no brackets have been moved and no blocks
06-21-2017, 03:26 PM | #3 |
I have 6, that's including the overload spring.. its level but i'm looking for a nicer ride in the rear..
06-21-2017, 08:40 PM | #4 |
I bought a blazer and was told by the PO it had a 6 inch lift never did any checking bought a 4 soft ride. The PO was wrong old lift was a 4. I have another blazer that I have had since 1981 when there were no lift kits that didn't include blocks. My dad knew what he was doing. took other leafs tapered them and added them to the stock leafs. Its a 2-3 inch lift best riding blazer of the 3 I own. I started a thread a while back asking the questions about lowering my new 4 inch lift down, There was multiple replies from guys who started by removing the wedge at the bottom to other combinations they removed to get the height they wanted. All said they rode fine
06-22-2017, 12:01 PM | #5 |
What would I do to install 56" springs with using stock perches and how much of a lift would I get?
06-25-2017, 06:44 PM | #6 |
The key to a better ride isn't the 56" spring its the company you buy the 52" spring from. The process that the springs are made with and assembled can vary from company to company. Hence the price difference on lift kits. Other wise go with stock springs and use blocks for the height.
