06-21-2017, 06:40 PM | #1 |
Need help Identifying this 350.
I have a 350 in my 72 3\4, and I need help decoding numbers on the rear of the block.
06-21-2017, 07:18 PM | #2 |
Re: Need help Identifying this 350.
0010 usually means a 4 bolt main block.
The information that would be more revealing is actually on the front of the engine block, on a slanted/horizontal casting surface....just below the passenger side heads front surface. There is a surface there that should have a bunch of alphanumerics punched into it. These will tell you if the engine is for the truck and if not, what it came out...year, etc. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
06-21-2017, 07:24 PM | #3 |
Hidden by the alternator?
06-21-2017, 07:30 PM | #4 |
Moderator
3970010 casting number identifies as a 350...one of millions...no way to tell if it is 4 bolt main or 2 bolt main unless you pull the pan,,,
Seeing its in a 3/4 ton truck, it has a better chance of being 4 bolt main... if you can read the vin or engine numbers on the block, passenger side front surface next to head mounting face and post those numbers, you will get a better idea of what you have... Hope this helps... |
06-21-2017, 07:40 PM | #5 |
Just began pulling the tank, Ill look when Im done.
06-21-2017, 08:54 PM | #6 |
The 0010 IDs it as a 350, 2 or 4 bolt main. Like has been said, truck block, most likely 4bolt. The other numbers tell when it was made, right down to the day a shift that made it. You can research it online.
06-21-2017, 11:22 PM | #7 |
70+ ( Old Skool Club )
Yoiur engine number should be something like this
V0215TDJ THis is the engine number form my 1972 C10 with a 350 V.. Built Flint Michigan 02.. February 15..Day in February engine cast/built, not sure which TDJ..1972 350 175HP 4BBl You'll probably have to scrape lot of goop off to read the engine number.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-22-2017, 01:16 PM | #8 | ||
"I ain't nobody, dork."
3970010 is the most common 4" bore block GM ever made. That number does nothing to tell if it is a 2 or 4 bolt. However, pretty much ALL trucks with 350's have 4 bolt mains.
The stamped number off the front machined surface just below the passenger side head will determine where and when it was built and what it's intended use was. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-22-2017, 01:25 PM | #9 |
I could only make out the a few digits K04 couldn't read the next then 12, and nothing else was remotely readable.
06-26-2017, 04:55 PM | #10 |
Alright heroes those numbers. 12y13b405 and K04 10 CKB.
Ive been doing some research of my own, according to Nastyz28.com I have a 1972 L65 165hp built in St, Catherine's Ontario, and it would of been in small gm cars. What do yall think? |
06-27-2017, 04:24 PM | #11 |
I see you got this pretty much figured out. Just thought I'd fill in the spaces.
12Y13b405 1 = Chevrolet 2 = 1972 Y = Wilmington assembly plant (Delaware) (passenger cars) 13b405 = 138405 = unique serial number K0410CKB K = St. Catherines, Ontario (McKinnon Industries Canada, engine plant) 04 = April 10 = 10th day (engine assembly date, April 10th) CKB = 350ci, 165hp, 2bbl, TH350 trans, RPO code L65, (Chevelle or Impala) In 1972 Chevelles had a starting number of 500001 at all Assembly plants. In 1972 Impalas had a starting number of 100001 at all Assembly plants. So your engine is from a Impala.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 06-27-2017 at 04:56 PM. |
06-27-2017, 05:31 PM | #12 |
Thank you sir. Now I know that its not an original, it won't hurt me to pull it and change it. And yeah, this decoding things not so bad, if the websites have correct information
06-27-2017, 05:36 PM | #13 |
Very desirable block. Mains are full cast, no "thin" engineering like mid 76 and later crap.
06-27-2017, 07:31 PM | #14 |
Will probably pull it eventually, once I can afford to get something with a little more hp and a little more torgue. I wonder what someone restoring an Impala will pay for the block, Ill have to see if heads match
