Old 06-22-2017, 01:27 AM   #1
CK5
CK5's Avatar
Touch up paint?
Has anyone purchased touch up paint from http://www.paintscratch.com/ before? Looking for dark blue for a 72 Blazer. Other places?
CK5.com
1972 Blazer Build
CK5 is offline   Reply With Quote
Old 06-22-2017, 07:55 AM   #2
A1971Blazer
A1971Blazer's Avatar
Re: Touch up paint?
I got some from here http://www.automotivetouchup.com/index.htm they mixed and put it in spray cans...
it's a base coat/clear coat type....
I repainted my dash with it....turned out great...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 06-22-2017, 10:11 AM   #3
hewittca
hewittca's Avatar
Re: Touch up paint?
I've also used automotivetouchup.com and liked it, until I found Tower Paint. They will custom mix paint from code or color match and put it in a can just like automotivetouchup.com, but they also have single stage available. I like the single stage for older vehicles because the finish more closely matches that of original paint, and can be worked if you need to. On a past project, I had to match some original patina. I got the color matched from Tower and it was dead on, and I was able to distress it to match the wear on the original paint.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 06-22-2017, 11:38 AM   #4
CK5
CK5's Avatar
Re: Touch up paint?
Sounds like both are great options, I actually would like to match the original patina on the firewall where a repair was made so maybe single stage would be best for that part.
A1971Blazer, your dash turned out great!
Can anyone confirm the paint code for a 1972 Chevy Blazer dark blue?
CK5.com
1972 Blazer Build
Old 06-25-2017, 05:44 PM   #5
dwkresin
Re: Touch up paint?
My 72 is supposed to be a factory dark blue and walmart brand royal blue/azul is a perfect match. So good that you cant tell where I done the repair. This includes a professional painter. If you doing a scratch you spray into a container then use a tiny brush followed by a light cut and buff.
dwkresin is offline   Reply With Quote
