06-22-2017, 09:07 AM | #1 |
Cab Differences manual to auto
Does anyone know if a manual cab can be made to auto? Or can the pedals not be switched and the trans tunnel different? Once upon a time I though only the tunnel cover was different
06-22-2017, 09:29 AM | #2 |
Re: Cab Differences manual to auto
Most people tend to prefer auto transmissions and convert their trucks over to it.
06-22-2017, 10:01 AM | #3 |
The steering column and shift linkage are changed. As is the neutral safety switch and wiring for it. The clutch pedal is removed from the pedal assembly. Just a couple that come to mind. The drive shaft will be a different length. And the cross member for the transmission must be located in a different location. I went from a 3-speed to a 700R4 years ago.
Smitty '71 Short Fleetside Spring Valley, Ca. |
06-22-2017, 12:48 PM | #4 |
As far as the Cab goes they are the same, on the Auto Cab GM put a small cover plate over the hole that the clutch rod comes out of, held in by screws. the pedal assemblies will interchange with a few bolts at the firewall and bottom side of the dash. all else is the same.
06-22-2017, 01:31 PM | #5 |
clultch pedal can be removed from the assembly. No need to get a different unit.
