Budget bed for budget AD build.
I installed a Classic Parts pine bed kit. I went with the pine since this truck still carries stuff and I'm on a budget.
Re: Budget bed for budget AD build.
It looks beautiful, forget the "budget" talk, it looks beautiful and you are using it. It doesn't get any better than that!
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#4 | |
![]() Brian
Post Whore
![]() ![]() Join Date: May 2015
looks good..just keep sealer on it and it'll last a while..don't forget to seal the bottom as well...my neighbor found that out last year..the sunny side of his looked good but the underside was a different story..
![]() ![]() Join Date: Nov 2008
Totally agree. If you want it to stay looking as good as possible while still using it consider buying the two part epoxy you can get at Home Depot or Lowe's and coat it after a light sanding. It'll make the softer pine more resistant to incidental dents.
If you're still gonna beat the crap out of it then pine was the best choice anyway. When/if it looks awful throw a coat of semi gloss black Rustoleum on it.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
I like what you've got there, it looks very good. NO need to say anything about a budget, you've got a great looking bed.
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
I gave both sides and all four edges of the boards two coats of boiled linseed oil. GMC Paul tells us that AD truck beds were sealed at the factory with linseed oil and lamp black. I also learned how to get right side up pics with a i phone.
![]() Join Date: May 2007
looks super duper
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
It looks great. I remember coating the flatbed on my grandfather's 48 1 ton with linseed oil after we rebuilt and redecked the bed in about 1961. That was my summer learning project with my grandfather that year. That bed is still out here at my place waiting for my brother to pick it up and put it back on the truck.
That does look good. Mine had an old, greasy sheet of 3/4" plywood for years. "Work truck" was all I replied when people made comments.
Excellent job. Many hours of careful work there and some are unaware the effort involved in bed replacement. I wish i could have used wood again (instead of "marine" plywood but weather on coast would eat it up in a few years.
#13 |
What's a good budget idea for the cross bars under the wood? My 52 is going to need one mayyyybe 2. Friend of mine with a 50s ford said he used those posts that hold up street signs with all the holes in them
#14 |
For cross member's I'm using heavy duty commercial shelf rack with the slots.. Its a u channel shape about 1x1x1. Many stores toss it when they remodel. Its seems ok for my application as tank comes close to bed. I had a pie of it and will add 3 cross rails to support the choicedek bed planks. Two pieces of bed rail welded together was my seond choice.
