Old 06-22-2017, 12:38 PM   #1
CanadianWolfpack
1964 LED light recommendation front & rear
Hello
I have a 1964 C10. I want to replace the 7" front lights and rear taillights.
Any recommendation that you have had good luck with
I want to go with LED
Jason
CanadianWolfpack is offline   Reply With Quote
Old 06-22-2017, 04:55 PM   #2
forestb
forestb's Avatar
Re: 1964 LED light recommendation front & rear
I would not recommend the ones that they sell at pepboys that have the little square lights on the side. Get ones where all the bulbs face forward. Also make sure that you get the electric flasher to replace the mechanical flasher or they will not work. Even then they may not work. I had some on my tail light and they worked fine but when I installed them on my front blinkers they caused all sorts of problems. Also if you order the ones that are integrated into the lens you might also have problems if you are trying to install them into the original tail light buckets on a step side. I bought a pair for my step side and they did not fit the buckets that I bought from the same company a couple of years before. I had to return them.
forestb is offline   Reply With Quote
Old 06-22-2017, 06:01 PM   #3
rvrfoot
Brothers trucks.Name:  DSCN0754.jpg
rvrfoot is offline   Reply With Quote
