ISO - rear seat floor plates etc..
Looking for the 4 rear seat floor plates as well as the 2 captured nut plates for mounting the front of the rear seat.
Also need the 6 bolts used to bolt the rear seat down. Attached pics of what I'm looking for, thanks. |
![]() Join Date: Apr 2006
Re: ISO - rear seat floor plates etc..
You would be better off making them yourself. That's what I did. You can buy those cage nuts from McMaster car far pretty cheap. I bought some sheet metal stock from tractor supply and cut the plates myself. Hard to tell it's not original and my blazer didn't come with a rear seat.
Kirk 72 Blazer CST 4wd highlander |
![]() Join Date: May 2011
I found 2 they do have some pitting I probably have the nuts also but would have to empty out the blazer and see if they are still there. I can't look underneath they sprayed the underneath with spray foam. Do you also need the channel that goes underneath for the rear seat mounts?
I might be interested in the underneath channel as long as it is from a 71-72.
Do you still need the other parts or are you good.
Thanks, I'll let you know, going to check out some local part outs this week.
Here is the channel it had a broken bolt so I welded a nut on what was left and heated the nut up. Threads look fine on all 4 nuts does have some pitting but no thin spots. 60 plus shipping if interested send me you zip and I will get a shipping quote.
Thanks for the pics 1rippen6, I was able to get all the parts I needed today locally.
I'm searching for that lower channel too for my 72 Blazer. I'm willing to pay up for a clean one like the one in the picture.
