06-22-2017, 03:17 PM | #1 |
Cruzzzn' Vet
Passed Smog
Just did my smog test and she passed, only low point was the HC (PPM)
Max AVG MEAS 135 73 120 Did a complete tune up, cap/rotor, plugs, filters and oil change. did a high speed run down the highway prior to taking it in, tech said it was passing unburnt fuel causing the high reading, possibly my Cat starting to go bad? Last edited by Malo83; 06-22-2017 at 04:28 PM. |
06-22-2017, 03:33 PM | #2 |
Re: Passed Smog
Bi-annual? Let's hope you don't have to go thru that routine every 6 months. That could get expensive.
06-22-2017, 04:13 PM | #3 |
Re: Passed Smog
Where was the CO reading?
06-22-2017, 04:20 PM | #4 |
Cruzzzn' Vet
Re: Passed Smog
06-22-2017, 04:22 PM | #5 |
Cruzzzn' Vet
Re: Passed Smog
06-22-2017, 04:34 PM | #6 |
Re: Passed Smog
Always a sigh of relief, mine barely passed this year my NOX was about 10ppm under the max, running too lean I think. When I got it back home I turned the screws out some more.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
06-22-2017, 04:59 PM | #7 |
Cruzzzn' Vet
Re: Passed Smog
06-23-2017, 01:18 AM | #8 |
Re: Passed Smog
Nothing wrong with the convertor, CO is fuel delivery and HC is the engines ability to burn that fuel. With those readings I wouldn't worry about it. If you go in next week when the heat wave is over, you'll get entirely different readings. What vehicle and engine we talking about?
06-23-2017, 11:07 AM | #9 |
Re: Passed Smog
I only had one square body ever pass emissions and it was as close as I could get to failing. I eventually just started plating them where there was no emissions
06-23-2017, 02:14 PM | #10 |
Cruzzzn' Vet
Re: Passed Smog
[QUOTE=kwmech;7974278]Nothing wrong with the convertor, CO is fuel delivery and HC is the engines ability to
83 Silverado, 305, 5.0 |
