Old 06-22-2017, 08:36 PM   #1
Steve1954
Whats it Worth - 1976 GMC Sierra 2500 4X4
Note: Admins, I guess I violated the rules by posting a "What's it worth". I apologize. If you need to remove, please do so and I will get compliant.
Note 2: Admins, I became compliant and became a premium member. - Thanks for your help mongocanfly.
Friend has a '76 Sierra Regular Cab 2500 4X4. He says its worth $15,000.
From My perspective, it is a mess. I told him that in the current condition it is worth exactly dick.
a) It was a basic red and had a silver "splash" painted on the side, which looks nice from a distance, but you can see and feel where the guy pulled the tape off - not original paint and not a great paint job at that.
b) he decided to "rewire" it, pulled out all the old wiring and bought a wiring kit (and then a second wiring kit) did not finish.
Ever see the movie "Gremlins"? Wiring is everywhere and nothing is connected.
c) he took all the door, floor, ceiling, dash panels and lights off in the cab to replace the wire (i know you have to). All those panels are spread out all over the garage. And many are broken.
d) I found the frame to the instrument panel .. . . and the speedometer cable . . but no speedometer, no gauges.
e) steering column is unbolted and laying in the seat - bolts not found
f) tail lights are hanging by the wires
g) truck has not been started in five years.
h) tires sat flat in the garage for at least 5 years
ok. maybe not "exactly dick" but my research indicates a good wiring kit is $750 and it cost another $750 to get it installed. And once it is running (if the engine even starts) it needs a safety inspection and registration. And it is going to need a new set of tires probably pretty soon which could be $600.
And when you get to that point, it is not a "classic" but it would be a pretty "daily driver" until the engine starts to go from sitting for 5 years.
My question is once it is running, what is it worth? (my guess is about $6,000)
What is is worth as it sits?
Would I get the $2 or $3 grand I am going to put into it out of it?
- or am I going to be driving a pretty daily driver for a while?
Last edited by Steve1954; 06-22-2017 at 09:36 PM. Reason: Became a Premium Member - can't post a What's it worth.
Steve1954 is offline   Reply With Quote
Old 06-22-2017, 08:42 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: What is it worth? 1976 GMC Sierra 2500 4X4
Need to be a supporting member to post a what it worth..
But..with all that I sure wouldn't give 15k...and doubt I'd give 6k..maybe 1-2k at most if it looks like everything's there..no way to know whats good and what's not
Old 06-22-2017, 08:52 PM   #3
Steve1954
My apologies, I will go back and read the rules again and get it squared away.
Old 06-22-2017, 09:24 PM   #4
mongocanfly
Post Whore
Re: 1976 GMC Sierra 2500 4X4
Here ya go.http://67-72chevytrucks.com/vboard/payments.php
Old 06-22-2017, 09:27 PM   #5
mongocanfly
Post Whore
The guidelines.http://67-72chevytrucks.com/vboard/a....php?f=34&a=17
Old 06-22-2017, 09:34 PM   #6
Steve1954
OK - Done!! Signed up as premium.
Old 06-23-2017, 12:50 AM   #7
Desert_Eagle02
No way 15k for that condition. Depends on the condition of the exterior and interior. And if everything is there and works, probably 2-3k. What's it have for a motor and transmission if any? Won't be worth too much as a fair condition roller.
1978 GMC K25
1984 Chevy Scottsdale K10 built 350 4"lift - SOLD
Desert_Eagle02 is offline   Reply With Quote
