Old 06-22-2017, 10:09 PM   #1
LowC-ten
68' C/10 Wheel stud question
Hi there. I just recently purchased a 1968 C/10 with the 6 lug rear end. I am trying to put a set of transport wheels on and the bore of the wheels is smaller than the face of the axle. I really don't wanna machine the center of the wheels out. I currently have spacers on, which do the trick. However, the stock studs are to short now and I need to replace them with longer ones. Can anyone tell me what size studs they used and where they purchased them? thanks in advance!
LowC-ten is offline   Reply With Quote
Old 06-23-2017, 04:24 AM   #2
GR8-68
GR8-68's Avatar
Re: 68' C/10 Wheel stud question
They are 7/16 on a 6 lug. then you will just have to get a length according to how much you need.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 06-23-2017, 06:08 AM   #3
7tee
7tee's Avatar
Yes 7/16"-20 thread, they can found at your locale parts store or they can get them...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 06-23-2017, 08:31 AM   #4
hewittca
hewittca's Avatar
I have transits on mine and had the centers bored out because I didn't want to run spacers. Turns out, even after changing the backspacing to 4" from the original 6", I still have too much backspacing and want to run spacers anyway. I searched around quite a lot for longer studs and ended up with these Moser studs from Summit. I also used these Cal Custom lug nuts because they have a larger seat to accommodate the larger holes in the transits which are meant for 14mm studs. With these nuts, studs, and a 1/2" spacer, the threads stick out past the nuts about 1/2" and the whole setup will still fit underneath a stock cap.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
