Old 06-24-2017, 10:52 PM   #1
hussler
hussler's Avatar
Replacement?? Brake Hose for disc brake set up
Hey guys i have a 1968 C-10 2-WD its had the front brakes converted to disc, it is a 6-bolt set up, im not sure but im thinking to kit is from CPP also has the drop spindles, well i need to replace the brake hose on the right side but not sure what make or year is compatible, its a banjo on one side and crimp on the other, its also about 12" long it would be nice when i go to the parts store to get the right part also would like to do the pads at the same time. any help would be awesome thanks!!
hussler is offline   Reply With Quote
Old 06-25-2017, 07:30 AM   #2
HO455
Post Whore
HO455's Avatar
Re: Replacement?? Brake Hose for disc brake set up
71-72 disc hoses will work. As that's what I used on my Burban. Mine is five lug now but i don't believe it should make a difference. There is a casting number on your calipers that with some searching on the interweb can be used to ID them. But I believe the pads are the same through 85.
RIP Bob Parks.
Old 06-25-2017, 01:38 PM   #3
hussler
hussler's Avatar
Thank you for your help!!
