06-24-2017, 11:51 PM | #1 |
157" C30 Question
Has anyone here put a pickup bed on a 157" cab and chassis frame? Please post pics if you have. If anyone has done this, it has probably been a crew cab or something similar. I'm curious to see how it would look with the way the frame "kicks up" at the rear.
06-24-2017, 11:59 PM | #2 | |
The Older Generation
Re: 157" C30 Question
You can put a Longhorn bed on a 133" cab & chassis frame but the bed for a 157" frame would have to special built..... Even with a crew I think the frame would be too long. LockDoc
06-25-2017, 07:06 AM | #3 |
I had a 157" C/30 tears ago and before I went with a service body I was considering shortening for a pickup bed. I had never seen anyone do a pickup bed on a C/30 chassis, so was on my own. I looked at it and was thinking the dip in the frame is too great, yet I never went into measurements. Do the 157s bend more than the 133s and pickups? Again, something I never checked or compared. But, that's something I've wondered about
06-25-2017, 09:34 AM | #4 |
SWB 4x4 Collector
157" frame
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
06-25-2017, 09:40 AM | #5 |
SWB 4x4 Collector
I didn't have to splice the frame. Worked out for my application.
06-25-2017, 09:47 AM | #6 |
SWB 4x4 Collector
I had to replace bed crossmembers.
06-25-2017, 10:21 AM | #7 |
Currently Blazerless
I had planed this with a lengthened stepside bed and found that the 157" chassis had a 2" higher rise at the kickup. I plan to split the difference and raise the cab 1" and lower the bed 1" by notching the frame to clear one bed crossmember.
Trevor, Your truck is looking awesome! How did you get around the extra 2" rise in the frame? And on wheelbase did you move spring perches up?
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
06-25-2017, 11:44 AM | #8 |
SWB 4x4 Collector
Thanks Rob, for this truck, I lifted the body 1", which also helps clearance I am sure for the Allison, I also removed a couple bed cross members and replaced them with the shorter type. I did not have to weld the frame back together, I moved the spring perches forward and rear crossmember. Then I could cut off the excess rear of the frame. This should be one stout frame for the Duramax.
06-25-2017, 01:41 PM | #9 |
Thanks Trevor for your reply and insight. You did a great job making the bed fit. Your truck looks awesome and should be plenty stout!
