Old 06-26-2017, 10:43 AM   #1
Ken B
Question on 8 lug aluminum slot rims..
I picked up a real nice set of vintage aluminum 8 lug slot rims with brand new BF Goodrich tires on them at the flea market this past weekend for 100 bucks. The seller said they were off a Chevy 4x4. Will I be able too use these on my 70 2wd C30? I believe my studs are 1/2x20 and the one lug that came with the rims has a larger thread size. When I went to get new lugs all the parts guy had were lugs that had a smaller outside diameter than the one lug that came with these rims that fit perfectly thru the lug holes... I don't want any wobbles etc... Is there any way for me to get around this? Thanks for any help!
Ken B is offline   Reply With Quote
Old 06-26-2017, 01:45 PM   #2
cleszkie
cleszkie's Avatar
Re: Question on 8 lug aluminum slot rims..
Find another parts guy or parts store. You should be able to find the proper mag-style lug nuts with the right OD and thread size at most any Pep Boys. Or go on-line and look for Gorilla brand mag-style lug nuts and order what you need.
cleszkie is offline   Reply With Quote
Old 06-26-2017, 02:01 PM   #3
Ken B
I think these are what I'm looking for?
http://www.ebay.com/itm/32-DUPLEX-MA...tTdEhm&vxp=mtr
Old 06-26-2017, 02:45 PM   #4
midniteblues
midniteblues's Avatar
I was gonna suggest the
"Lug nut king"
But I see you've already found him.
Much better quality than junk mcguard or rallie lugs.
He can set you up with excalty what you need.
I've seen some slots that have very unique lugs but pretty sure those were all unilug setups.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-26-2017, 03:06 PM   #5
WilliamFd55
I got mine from Lug nut king on eBay. He always has quality stuff. Had 8 lug on a 79 and just found 6 lug for the "New" 70'
WilliamFd55 is offline   Reply With Quote
Old 06-26-2017, 04:03 PM   #6
Sicklajoie
The Niner
Sicklajoie's Avatar
You're not really thinking of ditching the steel wheels are you?
You have one of the coolest trucks on this board!
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 06-26-2017, 07:46 PM   #7
Ken B
Thanks guys, I'm gonna grab the lug nuts from the Lug nut king..
I will keep the split rim and factory hub cap setup and I will no doubt put them back on at some point. Slots have always been a favorite of mine and every once in a while I like to switch things up a little. I also have a problem with one of the split rims. I've had for at least a yr. now a shimmy between 55 and 65 mph that drives me nuts. I have had it balanced numerous times to no avail. I put a junk rim and tire on to see if the problem goes away and it does. Maybe its the new Cooper tire but the tire shop swears it isn't, could be something out of whack with the split rim. I've also had to replace tubes on 3 different occasions because of nails and screws. One thing that really sucks about split rims (at least in my experience) is when you pick up a nail or screw its an instant flat, nothing slow about it. It has always happened in the worst places.
Old 06-26-2017, 08:15 PM   #8
CG
BlahBlahBlah
I bought brand new Gorilla shank style lug nuts off of Amazon for mine.
Old 06-26-2017, 08:54 PM   #9
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
I love that truck.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 06-26-2017, 10:36 PM   #10
I've taken drum brake K/20s and changed the studs to 9/16s.
Old 06-26-2017, 10:44 PM   #11
El Dorado Jim
what size tires are you running on your 8 lug wheels?
El Dorado Jim is offline   Reply With Quote
Old 06-27-2017, 12:46 PM   #12
WilliamFd55
They were 35/12.5/16.5 BF Goodrich.
Old 06-28-2017, 01:02 AM   #13
El Dorado Jim
thanks
Old 06-28-2017, 06:39 AM   #14
Ken B
I might want to get rid of the BF Goodrich road and trails and put a road tire on these rims. Where do you guys find 16.5 tires for a 10.5 inch rim? I'd like to find an old school looking tire if that makes any sense. I like to keep everything period correct looking. Seems no one around here has anything...
Old 06-28-2017, 07:36 PM   #15
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Unfortunately, not too many options left! I had to find another set of wheels for my crew cab build and sold off my 16.5 slots.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
