Wilwood Tandem M/C-pros and cons of plumbing separate front feed lines
The Wilwood M/C I will be installing (with proportioning valve kit) has 2 out ports for the front brakes so that you can run a dedicated line to each front caliper. I think that would be the better way to plumb the front brakes simply because in the event of failure of one side (which might be remote) you would still have the other side. Does that make sense? Any cons to that connection?
Thanks, Phil |
Re: Wilwood Tandem M/C-pros and cons of plumbing separate front feed lines
Hmmm... It's not all positive.
Imagine this: Once side fails while you are doing a very hard stop. If your reaction is very quick, you might avoid a spin/rollover, but the truck will go out of control most likely. With a single feed, you'd simply have no brakes all of a sudden rather than dealing with the result of loss of one side only. Twin engine pilots train for engine failure on take-off run but many still crash when it happens for real. It's about what happens in the moment of need, not exactly a good analogy, but... -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
It's just a trade off of pros and cons. If manufacturers had a legitimate concern for the issue you stated (or if a regulating body could find concern), they would have integrated that from the factory, or at least made it optional.
One wheel braking is dangerous, that's why the safety mechanism is done in pairs with a dual MC. |
I dont think it works that way, if you blow a line the other side will lose pressure out of the blow out and you will be left with rear brakes only. You cant maintain hydraulic pressure with a hole in the system.
Instead of running one line out of a standard type proportioning valve and then down to a tee, from the tee to each wheel. You instead have the tee build into the proportioning valve. |
Post Whore
![]() Join Date: Feb 2016
I believe Sprint9 is correct. In order for it to be completely separate you would have to have separate feeds from inside the master cylinder. Or a complex set of check valves. I believe they offer it with the dual feed is so the race car folks can run the exact same length of brake line to both front brakes so both cylinders work at the same time. But check with Willwood to be sure.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
I ran both front lines on my truck the first time and this time I ran a single to a tee. There's no difference in braking but the brake lines are much cleaner and less likely to fail. And if you lose one side you lose them both. My cpp stainless braided hose broke on one side and sent me into a busy intersection a couple years ago
Thanks all. Very interesting responses. The decision is not so simple as I now see.
Phil |
Assume="make an @ss..."
My bad! I too have experienced loss of pressure in a '94 GM F-Body with Baer big brake kit. The braided line on passenger front gave out under hard braking. Fortunately nothing bad resulted that day other than brake fluid all along the side of the car, but it was a very scary event. I was intentionally hard braking in a safe area, testing/breaking in the hardware. -klb
Old member
The front two line connections are both in the same stroke area of the cylinder so if you loose pressure to the front side of the M/C you will loose both front brakes. Putting a tee fitting in the front is how the factory did it less fittings to keep from leaking.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
