Old 06-27-2017, 02:15 PM   #1
Enduro55
Brake lines
Where is the best place to get pre-formed brake lines?
Enduro55 is offline   Reply With Quote
Old 06-27-2017, 02:55 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Brake lines
Have you tried LMC yet?
Old 06-28-2017, 12:01 AM   #3
vince1
Re: Brake lines
If you are not doing them all most parts houses have an assortment of lines made up of varying lengths.
If doing them all it would be nice to get a complete set but then trying to hook up lines to non stock dual cylinders of varying origins might muddle things up a bit.
vince1 is offline   Reply With Quote
Old 06-28-2017, 10:59 AM   #4
jayoldschool
Moderator
Re: Brake lines
For the price of a pre-bent set, you can buy a really nice hydraulic flaring tool and a coil of tubing...
jayoldschool is offline   Reply With Quote
Old 06-28-2017, 12:17 PM   #5
The Rocknrod
Moderator
Re: Brake lines
This is the one I have.
http://www.ebay.com/itm/Mastercool-7...cAAOSwCmZZT3Qa
Old 06-28-2017, 03:43 PM   #6
padresag
Re: Brake lines
this is all you need plus a tubing cutter which are not that expensive. you will need the right size double flare bit which is that little black round thing at the top. this one I have had for over 50 years
ron
padresag is offline   Reply With Quote
Old 06-28-2017, 04:29 PM   #7
pimpston65
pimpston65's Avatar
Re: Brake lines
in-line tube has pre-bent in steel or stainless. plus their in Mi.
pimpston65 is offline   Reply With Quote
Old 06-28-2017, 05:08 PM   #8
jayoldschool
Moderator
Re: Brake lines
I used Ron's style of flaring tool for years. Once I tried this... never, ever again. They're inexpensive now.
Old 06-28-2017, 06:39 PM   #9
The Rocknrod
Moderator
Re: Brake lines
Yep, me too. Never again.
Old 06-28-2017, 07:54 PM   #10
padresag
Re: Brake lines
I must admit the old one does take some practice to get use to using it, but it does the job and was not made in China. if you were doing them everyday then there are more than likely more efficient ones out there. for the money how often are you going to use it and that new kit is also for metric and other uses which you may never use.
there is only a 30/30 warranty on it also. I see that the dies also do not hold up for long on stainless.
here is a selection
http://www.ebay.com/bhp/double-flaring-tool
ron
