Old 06-27-2017, 10:22 PM   #1
Coach
Coach's Avatar
Stalling issue - need advice
I've had the truck for 3 years and never had this issue before. I washed the truck today since it was filthy. After that I made a slight adjustment to the curb idle speed (raising it from 500 to 650, just to see any performance difference). Went for a drive and after about a mile, the truck completely died on me as I came to a stop sign. I was able to get it started after a couple tries. A few blocks later, it did it again. I went home and adjusted it back to 500 (where it has been for the last year). Drove it again and the same thing happened. When I finally got it started, it smells like it is running really rich now. I have an HEI Distributor and Holley 670 Street Avenger carb with a small block 350/290. Not sure what it could be, possible float bowl issue?? Any advice would be appreciated.
1967 Chevy C10 Stepside SWB - 350/700r4
Coach is offline   Reply With Quote
Old 06-27-2017, 11:32 PM   #2
RMBLFSH
Re: Stalling issue - need advice
Not being disrespectful, but have to ask: are you sure the screw you turned both times was the idle speed adjustment screw?
RMBLFSH is offline   Reply With Quote
Old 06-27-2017, 11:51 PM   #3
Coach
Coach's Avatar
No offense taken...Yes it was
Old 06-28-2017, 12:41 AM   #4
randy500
Could it be possible the secondaries are open a tiny bit causing it to be way to rich if they are dripping fuel or lean if they are not dripping, try closing them by hand
randy500 is offline   Reply With Quote
Old 06-28-2017, 12:41 AM   #5
edhtrd71
Hi, did you wash the engine or could water have got into the distributor? I have seen lots of hei's get wet under the coil cover. They will act just like what you are describing.
edhtrd71 is offline   Reply With Quote
Old 06-28-2017, 12:58 AM   #6
Coach
Coach's Avatar
I didn't wash the engine, but I guess it could be possible the distributor got wet in the process of washing the truck.
Old 06-28-2017, 02:06 AM   #7
edhtrd71
It may be worth pulling the coil cover off and looking for humidity inside under the coil.
Old 06-28-2017, 08:20 AM   #8
Marine-58
Marine-58's Avatar
If not moisture in the distributor, have you looked for any vacuum lines that may have come off?
72 Chevy C10 383/465
69 Corvette convertible 454/650
Marine-58 is offline   Reply With Quote
Old 06-28-2017, 08:36 AM   #9
rockyrivermark
That's my bet also. Maybe you axcicenfy pulled a vacuum line off. Check or any cracks on the vacuum lines also.
rockyrivermark is offline   Reply With Quote
Old 06-28-2017, 12:12 PM   #10
Lanman1972
Lanman1972's Avatar
Mine was doing this after the winter storage and ended up being clogged fuel filter.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 06-28-2017, 12:14 PM   #11
davepl
davepl's Avatar
Random guess - Do you have the factory air cleaner? Maybe you unhooked the vacuum line for the Thermac to take it off to adjust the idle and forgot to reconnect it?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-28-2017, 12:26 PM   #12
AussieinNC
Moderator
AussieinNC's Avatar
Water could have infiltrated the HEI system if the Cowl to Hood rubber seal is either missing or degraded.
I have seen trucks with no seal literally stop in the middle of the road during a rain shower. Water drops straight down onto the distributor...
LMC have the seals # 38-7410 for $ 8.99
Remove the HEI cap and coil, remove the coil and make sure it is totally dry...make sure the inside of the HEI unit is totally dry...
Hope this helps
AussieinNC is offline   Reply With Quote
