06-28-2017, 07:48 PM | #1 |
Its a Truck Thing......
One Ton Suspension Upgrades
I just picked up a 72 Motor Home. Will the crossmember from a 85 one ton bolt up in place of the stock one? I want to change the drivetrain to something that has parts available. Looked at a few sights and no one has rear drums for a dually. Did some searching here and everything that comes up with changing to 4wd from 2wd which is not what I am trying to do.
Thoughts? Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
07-03-2017, 03:01 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: One Ton Suspension Upgrades
Yes they will swap. 73-90 1ton
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
07-03-2017, 05:04 PM | #3 |
It will bolt right up without any issues except one hole,the front lower bolt hole on the side of the frame is off just a little. I used a dremel to wollow out the bolt hole so it would line up... don't pay any attention to the gouges on the frame where the dremel went rogue.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
07-04-2017, 12:09 AM | #4 | |
Picked up a complete front and rear assemblies. Got to see what the gearing is on the 14 bolt. Great pick 69gmcc10. Smitty
07-07-2017, 10:30 PM | #5 |
Couple options as well. You can keep the original front crossmember and run a set of PBFAB control arms, they can be made with 73-91 balljoints, 1" forward and 1" in to allow for better wheel alignment in wheel well and wider wheel/tire. Then you have more brake options too. You can run drop spindles for 73-91 at that point as well.
I'm going to run this with a higher GVW brake spindles from a 84 1ton dually, trying to keep the true 1ton brakes. I'm swapping in a 4.10 14bff and making it disc brakes as well. Might switch to a 3.73 to make the sm465 a little better for top end highway driving. |
07-10-2017, 01:12 AM | #6 | |
Smitty
07-13-2017, 03:08 AM | #7 |
07-15-2017, 07:41 PM | #8 | |
Smitty
