06-29-2017, 01:47 AM | #1 |
1966 C20 Tires
Well I think it's about time for new tires. My truck is a 1966 C20 with I believe 16 inch rims (the current tires are a 7.00-16LT tire). I do a little towing not much (just dirtbikes and fourwheelers occasionally), but mostly just normal daily driving. I Measured my current tires and they are about 31" tall give or take a little and I would like to stay close to that height in order to be able to drive on the highway and not be turning really high rpm's. Anyways, does anyone have a recommendation for tires/tire size? I'm also on a bit of a budget so I can't get anything to expensive.
06-29-2017, 06:42 PM | #2 |
Re: 1966 C20 Tires
I run 265/75/16's on my c20. They are equal to about 31 1/2. 10.43" wide. If I were to change anything I would probably drop down to 245/75/16. Almost an inch skinnier which equates to a little better mpg.
06-29-2017, 11:50 PM | #3 |
60-66 Nut
Re: 1966 C20 Tires
If you have fairly narrow wheels I would go with a 235/75R16 or a 235/85R16. IIRC the 235/85's are about 32" tall
