Old 06-29-2017, 10:05 AM   #1
msgtmac
Diamond plate
Thinking about Diamond plate in the bed of my 63 step-side. Any help with the install would be appreciated. Working on the cab now before pulling it off the frame. Bed is apart and ready to clean and paint. Thanks in advance. This is my first attempt at a frame up restoration.
msgtmac is offline   Reply With Quote
Old 06-29-2017, 04:20 PM   #2
forestb
forestb's Avatar
Re: Diamond plate
I don't think they sell sheets big enough so you will have a seam. Unless your truck is a step side, but even then it will only reach to the edge of the rails that are welded to the bed sides.
forestb is offline   Reply With Quote
Old 06-29-2017, 06:08 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Diamond plate
Somebody put a full sheet of diamond plate in mine. There are no seams.
66 C20 Service Truck:
Old 06-29-2017, 06:15 PM   #4
forestb
forestb's Avatar
Re: Diamond plate
wow does it go under the rails?
Old 06-29-2017, 08:32 PM   #5
msgtmac
Re: Diamond plate
My biggest question is how to take up the void left when the wood is removed. I am using .250 plate and there will be a gap on each end and over the cross members. I think it will be wavy if its not supported.
Old 06-29-2017, 08:39 PM   #6
LostMy65
LostMy65's Avatar
Re: Diamond plate
Yes
I'll see if I can get a look under mine.
Old 06-29-2017, 11:54 PM   #7
Captainfab
60-66 Nut
Re: Diamond plate
That .250" diamond plate is way overkill and way more weight and money than you need to spend. I would go with 14ga or no more than 1/8". Then make up the thickness different by building a framework from some 5/8" square tubing.
Old 06-30-2017, 08:57 PM   #8
msgtmac
Re: Diamond plate
Thanks for the info. Will work on that and post pics of my progress.
